193 heads, swap them out??
Old 08-23-2011, 12:36 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
I bought a motor from an engine shop with full 5 year/50,000 mile warrenty. 4-bolt main 383 came with XR264HR cam, 1.6 roller tip rockers, on 'profressionally ported' and cleaned up 193 heads. Combo runs well with plenty of torque in my 91Z28 TPI.
I am pulling this motor and dumping it into my miniram 91GTA.. hopefully it will be a good combination.
Here is my dilema; I have a nice set of 'home ported' 113 aluminum heads. So should I put them on now while the engine is out? Will I see that much gain, if anything? If I do change the heads, are they an exact replacement (direct bolt in), or do I have to measure rod length, etc.
Old 08-23-2011, 02:41 PM
Guest
Guest
Posts: n/a
Re: 193 heads, swap them out??
IDK about the bolts, since you're supposed to use washers under the head bolts on aluminum heads. But IIRC, the 193s are swirl-ports. If so, the power improvement should be dramatic! Unless the port job on the aluminum heads made them worse.
gta90
09-15-2015 04:00 PM
theurge
08-21-2015 12:46 PM
86White_T/A305
08-17-2015 12:16 AM
anesthes
08-08-2015 09:37 PM
Quick Reply: 193 heads, swap them out??
