MSD6A help ICM failures by bypass?
Old 12-12-2013, 03:18 PM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
Just curious I think I am heading down the ICM failure route replacing my 2nd one and 2nd coil for 4 weeks. And I have not even driven the car more then 30 minutes
I am replacing both at same time now and I will check grounding straps and grounds better. I have the small Dizzy 88 iroc
But I saw earlier thread where someone had similiarprobloems on older 85 dizzy and blew like 8 ICM over a few months and finally switched to MSD to elimnate the problem and and it worked?
How is this so? Dos the MSD just take the pickup coil signal into the MSD then from there process the spark and send it to the boot on the ign. coil?
I can see where this by pass the ICM since the MSD usually have the tach pickup. But then does it have a 4 wire input to accept the ECM plug?
RedLeader289
05-28-2019 01:47 PM
djmarch
05-08-2016 11:32 AM
$750 L98
11-07-2015 02:26 PM
Fanatic1074
10-02-2015 03:47 PM
RedLeader289
09-23-2015 06:50 AM
Quick Reply: MSD6A help ICM failures by bypass?
