Dies out after giving gas
#51
Car: '84 Camaro Z28
Engine: 305 HO
Re: Dies out after giving gas
Sure sounds like you're having battery issues.
#52
Car: '84 Camaro Z28
Engine: 305 HO
(I made another post, but it's not showing up for some reason, so I'll just say it, again ...) Yes, it sure sounds like a battery issue to me. First thing I would have done is to see if I could jumper it from someone else's car battery. You know the routine ... two cars next to one another with jumper cables connected. If that cranked it, then it rules out starter and battery cable from battery to starter.
#53
Car: 1986 iroc-z28
Engine: 305 ci Tpi
Transmission: 700 R-4
The only reason I took out my starter is because I thought the starter was bad because the voltmeter was reading 12 volts and I had bright lights in the car. So I took it to the shop and put it in a starter tester. And I'll try the battery thing when I get home today.
#54
Car: 1986 iroc-z28
Engine: 305 ci Tpi
Took the battery out and went to advance auto where they fully charged the battery and tested it. It came back bad. 325 cranking out of 650 and 13.7 volts.
#55
Car: 1986 iroc-z28
Engine: 305 ci Tpi
Rusty we have a newer snap on scanner too. When I go to the shop Monday I'll get the serial number off that one.
#57
Car: '84 Camaro Z28
Engine: 305 HO
Glad to see you got to the root of the problem.
#58
Car: 1986 iroc-z28
Engine: 305 ci Tpi
I just replaced it with the same kind of battery. Well we solved that problem, still have the rough idle problem to solve still
#59
Car: 1986 iroc-z28
Engine: 305 ci Tpi
Well bad news I went and put the new battery in this morning and guess what? Just a clicking noise
#60
Car: '84 Camaro Z28
Engine: 305 HO
See if it will even crank with a pair of jumper cables connected between your battery and another vehicle. It's possible the battery you purchased could be a bum battery. In any case, doing this will rule out or confirm that is the battery or cable. Also, ensure you have good, clean, and tight connections.
#61
Car: 1986 iroc-z28
Engine: 305 ci Tpi
Tried it no such luck. I went from battery to battery. It cranked 5 times then wouldn't crank again. I went from other vehicles battery straight to my starter nothing. I even ground Theodore to make sure it was a good ground but hey guess what still nothing.
#62
Car: '84 Camaro Z28
Engine: 305 HO
If the new battery is good, and if the existing cable is good, then I would guess that the starter is failing under load. And from what I've seen, when a starter is taken into a parts house to be tested, they don't have a spare engine that it gets mounted to for a load test. Replace the starter.
#63
Car: 1986 iroc-z28
Engine: 305 ci Tpi
I had a multimeter on the battery had someone try to crank it and the voltage only dropped a half a volt.
#64
Car: 1986 iroc-z28
Engine: 305 ci Tpi
Well good news, the solenoid on the starter was bad like I was thinking. Just went ahead and bought a new starter and solenoid put it on and it fires up like a champ! Thanks for all the help!👍
