finding battery drain
Received 1,672 Likes
Re: finding battery drain
All the ones that protect circuits that work when the key is off...
Brake lights, courtesy lights, etc. Quite a few.
Car: 85 Z28
Engine: 93 LT1
Axle/Gears: 3.73 01 SS
Headlight switch wires behind the dash had melted together on mine. If Those suspects don't work, narrow it down to high voltage components that are hot with engine off, and trace the wiring through a little and see if you notice anything suspicious.
1 Post
Car: 92 RS
Engine: Sbc With h/c/i/e holly4150
Transmission: 700r
disconnect battery cable and put multimeter between cable and post. then watch reading as you pull fuses when voltage drops then you know where your problem is.
i guess it was the battery itself. had napa check it and it was reading under 100 cca. grabbed a new battery and havn't had a problem with leaking down, yet.
db057
08-11-2015 10:11 PM
