Please Help! Fuel Pump Not Working
Old 08-16-2015, 09:17 PM
Glowsock's Avatar
Car: 1989 Firebird
Engine: 305 TBI
Hello everyone, I have a 1989 Firebird 305 TBI, I'm having issues with the fuel pump, the car stalled a few times, and now it will not start at all, the fuel pump does not prime when the key is turned and the gas gauge sais it's over full, if I'm correct that means there's no power getting to the pump and sending unit? I replaced the fuel pump, the fuel relay (If the relay in the picture is the right one) I noticed that the relay and plug are a bit burnt. Also I followed the ground wire from the pump and put a new end on it as well as a new bolt because they were pretty rusty. Still no luck with getting the pump to prime. About a month before this problem started I have a PROM Chip burnt to bypass VATS, not sure if that would have anything to do with it? Any help would be greatly appreciated as this car is my daily driver!
This is the relay that is burnt, is his the correct one for the fuel pump?
Old 08-18-2015, 06:07 PM
FalconZ28's Avatar
Car: 1986 Corvette, 1985 Z28
Engine: 383 Vortec HSR, 350 Vortec TPI
Transmission: 700-R4
Axle/Gears: 3.83
Re: Please Help! Fuel Pump Not Working
That looks like the correct relay for a TBI.
Have to tried jumping the relay to see if you can get the pump to come on? I'm afraid I can't advise on which wires to bridge, I'm only familiar with TPI relays.
Old 08-18-2015, 08:24 PM
djmarch's Avatar
Car: 1989 GTA
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
Curious as to where you bought your relay ?
Old 08-19-2015, 09:18 PM
Glowsock's Avatar
Car: 1989 Firebird
Engine: 305 TBI
I haven't tried that yet, would that be worth doing even with the new relay?
Glowsock's Avatar
Car: 1989 Firebird
Engine: 305 TBI
I purchased the relay from Lordco Autoparts
Old 08-19-2015, 10:25 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
Could be the small fuse on the driver's side just behind the charcoal canister area. Had a similar issue there. When I tested my relay, I just used a test light to find the one that had 12v power and then jumped every wire one by one until the fuel pump came on. However, I'm only telling you what I did and not telling you to go and give every wire on that relay 12v, I'm just saying that is how I did it. I'm sure you can find a wiring diagram for the engine on the austinsthirdgen site. I only did what I did because I was in the moment and working on the vehicle and did not want to stop just to go and research , however that does save problems and future money
Old 08-19-2015, 10:29 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
Also, when I ran TPI my relay had 5 wires going to it , this could differ but someone should verify that is the correct relay you are replacing
Old 08-19-2015, 11:25 PM
Glowsock's Avatar
Car: 1989 Firebird
Engine: 305 TBI
Thanks for your input! what fuse are you talking about? Not familiar with a Charcoal Canister!
Old 08-21-2015, 09:27 PM
Glowsock's Avatar
Car: 1989 Firebird
Engine: 305 TBI
Pretty sure my relay has 5 wires as well. Does the bigger black wire with a red stripe and the bigger red wire from the relay end up near the battery? The black leading to a fuse, and the red leading to a fuseable link looking piece of wire ?
Old 08-21-2015, 10:08 PM
Glowsock's Avatar
Car: 1989 Firebird
Engine: 305 TBI
My mistake the relay has 4 wires. What setting do I use on my multimeter to check if there's power to the pump and on the pumps power wire at the relay
Old 07-21-2016, 01:38 PM
Whiterider89's Avatar
Hello Glowsok, did you ever figuer out you problem i am having same issue with my 89 bird?
Old 08-02-2020, 07:36 PM
mike85nc's Avatar
Hello everyone... I know this post is a tad old but wanted to share my issue. I have an 85 iroc z. The fuel gauge never read correctly. I just installed a 1AAuto fuel sending unit with the new seal. After i hooked up the wire harness from the sending unit to the the body connector behind the rear seats... I get nothing. So i had to imprevise. I testes the wires on the body connector (had to cut it off) Pink wire is definitely the power wire, Black wire is obviously the ground wire and the Tan wire im told is for the fuel pump but it doesn't pertain to me bc i have an external fuel pump.
On the sending unit i have a Purple wire ( assuming its the power wire) A Gray wire (no clue here) and a Black wire with white stripe. So i just hooked up wire for wire....Pink-Purple....Gray-Tan & Black-Black w/ white stripe.... And i get..............
An incorrect reading. I know i have about 8.5-10 gallons of fuel in the tank so logically it should read about 1/2-3/5 full.
My question is did i hook up the wires correctly???
Any help on this would be great, since i have no clue whats going on.
92camaroJoe
07-29-2023 07:57 PM
Grant2k
07-10-2018 04:01 PM
mustangman65_79
04-14-2017 05:37 PM
92camaroJoe
08-13-2015 06:07 AM
Quick Reply: Please Help! Fuel Pump Not Working
