Loud "PSH!" sound when starting up engine...
Old 09-03-2015, 08:47 PM
Blue419's Avatar
Car: 1986 Trans AM
Don't know how else to describe it lol.
I just replaced the intake manifold gaskets on my 86 T/A. The engine started up, ran rather roughly, and made a couple of "Pssh!" sounds (like a rapid release of air). Now it smells kinda bad too.
I'm still kind of new to this... Anyone have any idea what would make a sound like that?
Old 09-09-2015, 03:16 AM
Ilango's Avatar
Re: Loud "PSH!" sound when starting up engine...
Sounds like an air leak. Have you connected the vacuum line to the brake booster?
Old 09-10-2015, 12:51 PM
tyeo098's Avatar
Car: 88 Chimera
Engine: 1994 LO5 5.7L
Axle/Gears: 2.73...?
+1 on double checking vaccum lines.
You had to take them off to get the intake off, right? One probably isnt seated all the way.
Or maybe someone replaced your car with a Chrysler Turbine
Old 09-10-2015, 01:03 PM
AmpleUnicorn88's Avatar
Engine: 305 TBI/305 TPI
Transmission: World Class T5/missing
Axle/Gears: 3.08/G92 3.45 posi
My buddy had the same problem when he got the motor back in on his. He just hooked up the vacuum lines wrong on the diverter valve so it sounded like a loud air leak when he started it and while running. But it's most likely a vacuum leak.
Orr89RocZ
04-25-2016 08:28 AM
Andrew6.688
12-13-2015 10:59 AM
db057
08-22-2015 08:17 PM
gta power
08-13-2015 06:15 AM
Quick Reply: Loud "PSH!" sound when starting up engine...
