Pop or backfire on acceleration
Ok guys new to the forum and need some help. Have an 89 iroc 5.7 tpi that makes popping or backfire sound sometimes on acceleration from stop sign or if I give it a lil gas after at one speed for awhile. If I hammer it after it does it, I can run tach to 5500 and takes off like a banshee with no missing hesitation. I've changed plugs wires cap rotor, cleaned maf sensor, intake temp switch. Car isn't running hot, started doing this when it got warm out. If it's weak fuel pump I shouldn't be able to run her hard without it puking on me right. One time it did it I smelled gas. Could it be purge valve/solenoid on charcoal canister? Plus it's not showing any codes/ no lights on. I did have to do an ignition bypass on car because ignition lock for vats crapped out but mechanic did that with a kit he bought, wasn't cobbled . Outta ideas
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Pop or backfire on acceleration
Most likely timing when it backfires through the carb
Pac J
05-17-2020 10:44 AM
RedLeader289
05-28-2019 01:47 PM
