92 305 wont start...
ive tried multiple different things, and spent hours searching for a possible reason as to why my car wouldnt start. ive replaced the icm and the battery. i have tried to use starting fluid, however that took me nowhere. im starting to think it may be a spark plug problem, however im uncertain at this point. any help would be appreciated, thanks in advance.
Re: 92 305 wont start...
im gonna check out my injectors once i get back.
Car: 1992 RS
Engine: 305 5.0L V8 TBI
Did you just buy the car off someone or have you had it stored away? When you turn the car does it attempt to crank or is there no noise at all? Check the condition of the wiring coming off the battery to the starter. Take a video of you trying to turn the car on.
i got it off of my mothers boss back in august. it used to run beautifully.
when i try to start it, it cranks but just doesn't start.
i dont know if this may be relevant, but my automatic gear shifter moves withouy pressing the break and/or button the the top of the shifter.
dennisbernal91z
04-14-2016 05:37 AM
