Gasket sealer on a metal headgasket...do I?
Car: 92 Camaro
Axle/Gears: stock
The Helms manual I have says to use a gasket sealer on a metal head gasket. I'm going to be using the GM 0.028" metal head gasket, should I use any sealer, possibly blue RTV or Indian head Gasket shellac?
Re: Gasket sealer on a metal headgasket...do I?
Car: 1991 Formula
Engine: 305 TBI
I have a service manual in the garage I can look at and see if they specify one somewhere if you'd like, probably tomorrow as I'm heading off for the night.
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
hey hey mikeyt know of any chill cruise nights in the Norfolk/Virginia beach area?
Received 1,672 Likes
WHATEVER the best thing is, it is NOT Indian Head shellac.
.028" should be a composition gasket.
Metal (steel shim) gaskets are usually more like about .016" thick, and are basically guaranteed to leak. See all the comments about Indian Head shellac to get a feel for why: they are simply OBSOLETE. Can be fine for a pure race-only car, where "longevity" isn't an issue; pretty much CERTAIN to fail in a street car, especially without very careful prep. Usual treatment for them in such circumstances is spray copper stuff.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I use MLS gaskets in my engine. I just spray them with copper coat.
Car: 91 RS VERT
Engine: 305 9.67 2.02 58 cc 282 480 108 LC
Axle/Gears: 4.11 POSI
I went with metal .015's and copper spray coated them - just as insurance .
Car: 92 Camaro
Axle/Gears: stock
From all that you guys have showed me, the Indian head will not be used. I just read the same thing you posted in the manual...that's too funny
1Aauto
Sponsored Vendors
06-08-2016 09:01 AM
