Attention ALL TPI owners...inside please...
#151
Car: 92 Camaro RS
Engine: 88' L98 w/92 tpi conversion
Axle/Gears: Stock one tire Fire!
Re: Attention ALL TPI owners...inside please...
Worked just fine for me, just read through all the posts and u will find some that work... and allot that don't.
#153
Car: 1986 iroc-z28
Engine: 305 tpi
Transmission: A4
can anyone tell me why my rearend feels like it moves a little
#155
Car: 1991 GTA
Transmission: Stock
Axle/Gears: Stock
Mark thanks for re-posting the article, I just downloaded it and am now set for some Sunday morning reading.
#156
Is this the article you are speaking of?
http://mpikas.blogspot.com/2008/08/t...june-2000.html
You can save the whole thing from this site as JPG images....
#158
i went to try the link you supplied, but it doesnt work anymore. if there is any way you know of for me to get a hold of that it would be greatly appreciated.
#160
Car: 1989 Iroc-Z
Engine: 5.7L 350
Axle/Gears: Disc Posi
yes please...never mind just looked up.
#161
Car: 85 Camaro Iroc Z-28
Transmission: 3spd. auto
Axle/Gears: 4:11 posi
so how can i get this article, do i need to go search for it on hot rod magzine or anyone have the address, thanks
#163
well dam, my bad didnt mean to sound stupid or notin
#164
anyone know how I can tell if my 85 iroc Z has a 305 or a 350 from just lookin at the motor
#166
the vin aint gonna help, I know the car factory came with a 305 but i was told by the guy that a 350 was put in semi built with a mild cam. so I'm tring to see if hes crappin me or not. so far i hear i have to tear down engine and the heads will have numbers, and if i measure the bore in the piston walls that will tell me the block. cause i also cant see nothin on the back block of bellhousing. I just didnt know if there are any tricks to identifying these from just lookin at a certain thing on them. thanks
#167
Car: 1989 Iroc-Z
Engine: 5.7L 350
see if you can use a light and mirror to check the casting number on the block and run that on the net or call it in to your local GM dealer. Thats all i know....hope hat helps a little more.
#168
Car: 1987 Chevy El Camino
Engine: 357 CID w/Lingerfelter Super Ram
Transmission: 700-R4
Axle/Gears: GN 8.5 342's
http://www.mortec.com/castnum.htm
You should be able to see the casting number on the drivers side of the block on the ledge below the distributor and above the oil filter casting.
Thanks,
Dave
#169
Here is another link that has a picture of how the casting number looks on the block-
http://www.chevyasylum.com/tech/decode.html
Thanks,
Dave
Thanks,
Dave
#170
Car: 64 elcamino
hi
i would like to read but it will not open do you have and address so i can try and read it
#171
Car: 91 Camaro RS
Engine: Carbureted 305
can someone actually post a link that works. And in PDF format so we can actually read it? It's too hard to read them when they're jpegs.
thanks!
thanks!
#172
The article on TPI Tuning is unavailable to me even though I tried every way possible to access it. I went to POST # 60 was unable to retrieve it. Could you please POST it again here or send it to me at rande_always@hotmail.com
Thank you and have a Joyous and prosperous new year to you and yours.
Sincerely yours,
Robert
Sincerely yours,
Robert
#176
Car: 91 Camaro RS
thankyou drb930! I have created a pdf with those jpegs, and hopefully this will work for anyone else trying to access it.
Could not upload it as it is over 1MB, so here is a link.
If you have a problem, accessing it, just pm me and i can email you a copy.
http://dl.dropbox.com/u/1131524/TPI_PDF.pdf
#177
yea, those appear to be mine from here, which have always worked:
https://www.thirdgen.org/forums/post...9-post140.html
#178
I down loaded the pdf file and saved that as well.
Thanks,
Dave
#179
#180
I have a 91 s10 with a 355. I just bought a 89 corvette tpi with computer and all the wires and plugs still in tact. I need injectors but not sure of what size or kind. I eventually want to put all this in my 48 chevy Fleetline. Is there anything else i'm going to need to make this work?
#181
#182
I think the Vette L98 used 24lb injectors. Those stock units were pretty well known to have problems with today's gas.
#183
Look here- http://chevythunder.com/since_its_inception_in_1985.htm
Thanks,
Dave
#185
Car: Dodge Coronet 74
Engine: 225cid -> SBC 383
Transmission: A904 -> T56
Axle/Gears: broken =)
drb930
Thank you very mach!!!
#188
Scott AKA YL
#189
Car: 1993 Caprice Classic "Woodie"
Engine: 350 TBI W/EBL Flash
Transmission: 4L60 S10 converter
Axle/Gears: 8.5, Torsen T2, 3.73s
I don't know who helped write the book but John Braechtel has been around cars longer than that................
#190
Car: 91Z28
I seeyou guys talking about this article...i clicked on it and i cant seem to get the page to load ......my email is camarochris91z28 if you guys could somehow send me the article it would be greatly appreciated....seems like it may be verry helpfull.
#191
If you are unsuccessful, post, and I will e-mail you the file.
But both of these pdf links on this page worked fine for me.
Thanks,
Dave
#193
Car: 89 Iroc
Engine: 5.0L
hello I'm new to the tpi world. I just bought an 89 iroc 5.0L with 55k miles on it in great shape. I am swapping out the injectors as I already had a 2 bad ones. Can I use the 5.7 injectors? I would like to make an extra 50 hp without losing the stock look.I already have done cat back exhaust. My list of todo's are: injectors,throtte body air foil, hot coil,k&n,egr valve, fuel pressure regulator(50psi)....anything else or do's or don't.I am gathering as much info as fast as I can would like to get this done asap. thanks much!
#194
Car: 64 elcamino
hello
i am running the stock replacements from FIC in my 305 tpi,,, i had the 5.7 injectors in but had no GAS mileage....An at 3.10 a gallon .so it's up to you...
#195
Thanks,
Dave
#196
Car: 89 Iroc
Engine: 5.0L
so just a quality 19 psi injector then? thanks guys
http://tpiparts.net/inc/sdetail/2545
these good?
these good?
#197
Car: 89 Iroc
Engine: 5.0L
where do i check the tps voltage and what should it be the link on the other page i found doesnt have it. sorry to be a bother
#198
Very nice. But wow, just went through tons of trouble to find out the fuel pump was going bad...
#200
hello i want to put Lt1 heads on my 86 tpi 350, i've read all i can find on this subject, but i can'nt pull up the pic's. can any one help? PLEASE
