150K miles..Should i replace my stock valve springs?
Old 02-15-2007, 04:46 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
My TPI L98 motor runs very strong. No signs of wear and tear really even for 150K miles now. I've replaced the TPI gaskets since a rear manifold oil leak occured and now its all fixed up. The lifter valley is clean..i frequently change the oil. It recieves about 5K miles a year, mainly just summer daily driving. The car just has exhaust mods and 2800stall/3.42 gear and went 13.63 at 97 with the converter never locking up. As far as i know its bone stock original motor and never been rebuilt but who knows...
I was wondering if it would be beneficial to replace my stock valve springs at all? I was hoping to possibly get some 1.6 roller rockers just to squeeze more power out of my setup. While i was at it, i figured lets change the stock springs....they have to be worn since they are weak in stock form and have tons of mileage on them. Might improve efficiency and power??
My buddy has Z28 springs brand new and i was thinkin of gettin them. has valve locks and retainers too. This seems like a great stock replacement spring with alittle more lift range than stock. not that that matters tho since i will not be changin the cam.
I mean the car runs so good now i wonder if i should even worry about it.
Old 02-16-2007, 03:03 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
anyone have any input or advice...i'm sure its a good thing to do reguardless just be safe
Old 02-16-2007, 03:16 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
does the car smoke at start ups (like a small puff)? If so, I would change your valve seals, then while your in there why not swap the springs. If not.....I wouldnt worry about it. I changed my springs because I installed a bigger cam. I dont hear too many stories about stock springs breaking. But thats my 2 pennies anyway.
Old 02-16-2007, 03:24 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
most diffently a good idea. youve got my vote. and its not to hard if you have the right tools and a good day to work on it. the Z28 springs should beable to take those 1.6RRs too.
Old 02-16-2007, 05:57 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
no, the car doesnt smoke at all. i was just thinkin maybe my stock springs are worn out since they are a weak spring and maybe new ones would restore some power up on the top end. and with 1.6 rockers, i guess its good insurance to have fresh springs
Old 02-16-2007, 06:12 PM
Guest
Guest
Posts: n/a
I doubt it would be worth the effort. If you're going in there anyway, sure. But most rebuilt engines they just reuse the stock springs so IMO there isnt much point if the cam is stock too.
Old 02-16-2007, 07:04 PM
Damon's Avatar
Sometimes you'd be surprised how lousy stock springs are, even new. Even at only 5000 RPMs they can make a difference.
If you're in the mood for a project DON'T just replace, ALWAYS UPGRADE! A set of Comp 981 springs (or the afore mentioned "Z-28 springs") would be a significant upgrade over stock and either is a true drop-in replacement for the stock springs- no machining necessary at all. Couple that with some 1.6 rocker arms (why not, since you're in there already!) and you might just find your TPI has noticably more pull everywhere and doesn't drop off in the upper RPMs for a few hundred more RPMs.
Expect no miracles, but I've found stock-cam TPIs respond to better springs and higher ratio rockers quite nicely.
Old 02-16-2007, 08:13 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Replace the seals while you are at it.
Old 02-16-2007, 11:42 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yep my buddy has some Z28 springs, chromoly retainers and locks that i'm gettin off of him. i hope to buy some 1.6 rockers sometime next month or so.
Old 02-17-2007, 12:00 AM
BruceEmbry's Avatar
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
I have some good old fashion advice.
IF ITS NOT BROKEN, DON'T FIX IT.
Hay, you could just send me the money
customblackbird
08-15-2021 10:16 PM
NBrehm
08-25-2015 11:49 PM
TheExaminer
08-25-2015 07:34 PM
89mulletbird
Southern California Area
08-10-2015 10:16 AM
marcusaw
08-10-2015 08:13 AM
Quick Reply: 150K miles..Should i replace my stock valve springs?
