Fuel Pressure Regulator Kits
Car: 89 IROC-Z
Engine: 5.7 L V8
I have an '89 IROC-Z with the TPI 5.7 L V8. The car also has a hypertech performance street chip, Edelbrock exhaust system, and a ram/cold air induction system. I've been thinking about installing a JET or Crane fuel pressure regulator kit, but I'm not sure if it's worth the trouble. Does anyone out there know alot about this? Will this regulator do everything by itself? How hard is it to install and tune the thing? Do I need to install anything else to make it work correctly (new fuel pump, etc.)? Any advice would be greatly appreciated.
I don't think you would benefit from one with a basically stock engine. As for tuning with them, you need a fuel pressure gauge and time to fine tune it, it is easy to do,just time consuming. I would suggest putting money towards something else first.
http://sc3gfb.org/members/jason.html
1991 Camaro TPI, 355ci. Sportsman 11 heads, LT-4 Hot cam,Pete Jackson gear drive, on,and on, and on... 13.6 @ 102.5 with a 2:73 open rear, no traction, no tuning, no practice. Car is pictured in Chevy High Performance magazine, June 2000 issue.
1985 California Edition IROC red, polished TPI and polished wheels, otherwise completely stock 305ci. 700r4
1991 fullsize Blazer 4-wheel drive, 350,700r4, Pro Comp lift, K&N, TBI spacer, 3" Catco cat, 3" cat back Flowmaster, etc....
installation is simple,, all you do is unblot the plenum and the fpr is right there.. you unbolt the old one and bolt in the new one.. i would get one becasue increasing your fuel pressure will increase hp and atomize your fuel better causing better mpg. you can also make one if you are good with tools and dont want to spend the extra money. http://members.aol.com/mmmm999/3rd-d.../afpr/afpr.htm
surf this site,, its very informative.
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
I'd recommend the Holley afpr. It's got a **** on top instead of a nut and bolt so it's much easier to tune than the others. I've had mine on for a while and haven't had any problems with it moving.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N
9192camaro
16
02-03-2019 12:21 AM
