Timing ????
Old 02-05-2008, 07:06 PM
jadedcajun's Avatar
Timing ????
So I need some help .got an 85 305 when I unplug the sensor do I set the timing at 6BTDC then plug the sensor in and set the timing to 6BTDC ? I really don't think I'm doing it right ! Some body help me out Oh yea I'm pretty sure it's stock I just bought it about 5 months ago and was changing the wires plugs cap roater and stuff you know and I turned the distributor a little I didn't know I should have marked it before I started ! Learn something every day ! It runs but It doen't seem right hook me up some body please !!!
Old 02-05-2008, 07:46 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: Timing ????
there is no sensor involved,unplug the est wire engine off/ignition off.
start the engine(est wire still unplugged)
set the timing to 6 degrees.you may want to mark the timing tabs on the indicator next to the harmonic balancer for better viewing during timing set.
then turn off the engine,plug the est wire back in and you should be good to go.
BTW,welcome to TGO!
Old 02-05-2008, 08:14 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Timing ????
there are many posts on correct timeing for pretty stock engs. . the wire bundle over the heater/blower box has a wire . if i remember right its brown/black stripe . dis-connect this , set timeing to 0% , re-connect . you should be good to go . good luck .
Old 02-06-2008, 09:01 AM
jadedcajun's Avatar
Re: Timing ????
Kool man so when I plug it in and it moves it thats ok I don't have to mess with it anymore .! I'm try that out .It's raining pretty hard so I probly wont be able to try it till 2morrow . Thanks
Old 02-06-2008, 09:41 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Timing ????
You mean 6 degrees BTDC, right?
Old 02-07-2008, 09:35 AM
jadedcajun's Avatar
Re: Timing ????
yea man I was making it alot harder than it had to be Thanks alot !!!!
Azrael91966669
25
06-20-2017 04:04 AM
bamaboy0323
09-03-2015 06:07 AM
Feffman
Mid-West Region
08-13-2015 07:12 AM
Feffman
08-13-2015 07:11 AM
Thirim
08-09-2015 06:19 PM
Quick Reply: Timing ????
