88 Iroc wont rev over 3000 rpm
Old 08-30-2010, 02:02 PM
chrkevjac09's Avatar
Car: 1989 Rs
Engine: 5.0 TBI
Axle/Gears: Stock
My 1988 Iroc-z has a reving problem when I touch the gas pedal. It bogs out after it reaches 3000 rpm when i push the gas pedal but when i release it runs fine and shifts fine. If I push the pedal to the floor and hold it, it revs up to 2500 rpm and then acts as if it wants to shut off. It back fires through the intake and looses all power. Can someone please help, I've had this problem for 3 months and really just want to drive my car but can't. Thanks.
Old 08-30-2010, 09:21 PM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
Re: 88 Iroc wont rev over 3000 rpm
dirty throttle body or clogged cat?
Old 08-30-2010, 11:13 PM
Car: 1989 Rs
Engine: 5.0 TBI
Axle/Gears: Stock
I removed the cat beacause alot of people was telling me that was the pproblem and it didnt make a difference at all and i also cleaned the throttle body. i know its small i just haven't caught it yet. Im at a loss.
Old 08-31-2010, 12:24 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
did you check normal tune up cap, rotor, coil, wires,
timing @ Spec? fuel Pressure 36 -40 PSI??? no codes ??
Old 08-31-2010, 12:26 PM
sharkbait's Avatar
Car: 1975 Novamaro
Engine: 1988 305 TPI
What voltage do you have at the TPS at closed throttle and at WOT?
https://www.thirdgen.org/tpimod2
Old 08-31-2010, 02:52 PM
Car: 1989 Rs
Engine: 5.0 TBI
Axle/Gears: Stock
I changed all of those things spark plugs, wire, cap, rotor, coil, i have not checked the fuel pressure but I just put a new fuel pump in the car cause i thought it would help but didnt i will check the fuel pressure and see what it is around......and I dont know how to check the tps. How would i do that?
Old 08-31-2010, 03:35 PM
sharkbait's Avatar
Car: 1975 Novamaro
Click on the link I provided above for detailed instructions on checking/setting the TPS.
Old 08-31-2010, 04:59 PM
Car: 1989 Rs
Engine: 5.0 TBI
Axle/Gears: Stock
Hey I just tried adjusting the idle speed and did everything right and when i plugged the idle air control valve back up the idle didn't change at all from when it wasn't plugged in it just stayed at 450 rpm at idle in gear the car wouldnt even idle it would just die out. Does this indicate that i have a bad idle air control valve?
Old 08-31-2010, 09:34 PM
88gta3508's Avatar
Engine: 231 / 383
that is a indication your IAC is not working.. check with a Ohm meter across A&B / C&D
should read above 20 Ohms if not replace.....
a scan tool is the best way to check your TPS!!!!
you can use a volt meter DC volts.. factory spec 0.54v +/- 0.08v or 0.46 - 0.62
this method you will need to make jumpers
Old 08-31-2010, 09:59 PM
Car: 1989 Rs
Engine: 5.0 TBI
Axle/Gears: Stock
I did tried A&B but not C&D do you think this will make a difference?....and i also did a scan and the only code i got is that the car is running very lean.Thanks everyone..!
Old 08-31-2010, 10:20 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
I had a similar problem turned out to be a pin hole in the hose to the FP regulator
Old 09-01-2010, 02:52 AM
Car: 1989 Rs
Engine: 5.0 TBI
Axle/Gears: Stock
Yeah alot of people tell me the FP regulator would yours backfire through the intake? ill probably try this after the IACV.
Old 09-01-2010, 08:38 PM
Car: 1989 Rs
Engine: 5.0 TBI
Axle/Gears: Stock
So I replaced the Idle air control valve and it did not fix the idle problem...
Im starting to think it might be a bad ECU..
Old 09-01-2010, 08:52 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
whats your base timing, any vacuum leaks, mismatched spark plug wires, double check they are in the right spot, dont assume it is right, double check everything. have you checked your fuel pressure? probably not an ecu problem. Unplug your MAF sensor, and start it, does it run better? When does it backfire through the intake?
Old 09-01-2010, 09:22 PM
J91
J91's Avatar
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Possible faulty ignition module, i've seen this before...
Old 09-01-2010, 10:20 PM
Car: 1989 Rs
Engine: 5.0 TBI
Axle/Gears: Stock
i just replaced the MAF sensor yesterday it didnt make a difference i got the timming checked its at 6 degrees advanced .... It only backfires through the intake if I put the petal to the floor even if its in park it just jumps up to 2500 rpm and then looses power and begins to backfire through the intake until i let go of the gas ....it's weird because one day i got in the car to drive it around and warm it up and it drove perfect i raced and had a good time I thought it had gone away and then later that night it began to do it again and hasn't ran good since that day im really confused and wish i could drive this thing but i cant figure this out.
Old 09-02-2010, 08:14 AM
sharkbait's Avatar
Car: 1975 Novamaro
Is your timing advancing as give it throttle? What is the timing at 2500 rpm?
Old 09-05-2010, 12:33 AM
88gta3508's Avatar
Engine: 231 / 383
I would check your coil, PU coil & Control module
Old 09-05-2010, 01:20 AM
solaris_vii's Avatar
Car: 1997 z28
Engine: lt1
Transmission: t56
i had a similar problem in my 85 iroc, took forever to diagnose but turned out to be a corroded connector on the ecu, specifically where the ignition wires connected. i know you already suspected the ecu, so if i could find a known working ecu and try that in your car that might be a good starting point
Old 09-05-2010, 02:19 PM
Car: 1989 Rs
Engine: 5.0 TBI
Axle/Gears: Stock
yeah ill check it out and i did change the coil but where is the pu coil?
Old 09-05-2010, 04:22 PM
88gta3508's Avatar
Engine: 231 / 383
it's under the rotor.. to replace the P.U. coil ... you need to take the distributor Completely apart it looks like this Pic
I hope you are testing!!! all of the Components ??? and not just replacing
that will cost you Mucho Bucks...
we are suppling the Most probable solution...
ask or borrow a GM book for Testing Diagnostics
Old 09-10-2010, 12:55 AM
ruben0227jr's Avatar
just installed a ramjet cam in my 1988 iroc with a 350 tpi and now it wont rev past 3000 rpm by the way what helped the most with your problem?
Old 07-08-2015, 10:15 PM
Kblakney's Avatar
Car: 1991 Z 28
i know this is an old post but did anyone come up with a solution to this? my 91 Z28 is doing this exact same thing today.
thanks
Old 07-15-2015, 07:08 PM
TecknoMike's Avatar
Car: 1985 Trans Am
Axle/Gears: BW 9 Bolt 3:27
thanks
I used to have a bog at WOT problem a few years ago. I even had the backfire through the intake problem as the original poster of this thread too. At first I thought it was that Granatelli adjustable MAF that I had. I went back to stock rebuilt MAF and it helped my issues somewhat but I had strongly suspected my original injectors were shot. Are you still using the original fuel injectors? I finally got rid of all of my fuel mixture and power issues after replacing mine with some stock rebuilt injectors from fuelinjectionconnection.
Old 07-16-2015, 08:27 AM
Kblakney's Avatar
Car: 1991 Z 28
OK, after doing a lot of checking here are a few things i found.
tested all the injectors, 1 OHMed 0, 1 @ 3, and 2@ 13. replacing them with a set that all OHM out at 16.5
while the plenum and runners are off i found the EGR was bad, replacing that.
i took the vacuum line off the Adj Fuel Press Reg and found that it is leaking vacuum. the diaphragm is good so i put the factory cover back on and rececked and now it is sealed up.
also while the plenum and throttle body is off i did the coolant bypass. i am in the middle of puting back together. i will update when done to see if all of this solves the problem.
Old 08-02-2015, 09:26 PM
TecknoMike's Avatar
Car: 1985 Trans Am
Did replacing the FPR and EGR fix your problem?
Old 08-03-2015, 02:55 PM
Kblakney's Avatar
Car: 1991 Z 28
Yes TechnoMike, after replacing FPR cover back to the stock one and replacing EGR and half of the injectors with a set that tested out the same (16.5 Ohms) the car runs great once again. my 13 yr old has been drag racing it at the local strip in the teen 1/8 mile class and running 9.3 @ 78mph with a set of drag radials on it. i took it down the 1/4 on a test run and it ran 9.24 1/8 and 14.50 1/4. not bad for a car with 145,000 miles and all original suspension with all wore out bushings everywhere (this will be the next upgrade now that running good again).
Old 08-04-2015, 07:00 AM
TecknoMike's Avatar
Car: 1985 Trans Am
That's good to hear! I'm glad that you replied, since it should be helpful to somebody in the future searching the forums (and you said you would lol).
theshackle
09-17-2020 08:26 AM
mdtoren
08-16-2015 05:45 PM
mustangman65_79
08-11-2015 03:17 PM
Quick Reply: 88 Iroc wont rev over 3000 rpm
