What kind of fuel economy is everyone getting on their TPI?
#51
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
#52
Re: What kind of fuel economy is everyone getting on their TPI?
That guy bumped a thread from -2011-, I don't even really remember that far back.
#54
Seeing that you joined just shy of a year ago, you would not remember that far back. Personally, if it was my board I would delete your post and consider giving you an infraction. It was unnecessary, and personally people like you **** me off.
#55
Iv been a member here since about 2006.
Wow, im getting old. Wheres my medicaid and ginger snaps?
#56
#57
Seeing this thread is one of the reasons I'm looking to upgrade from my CC Qjet to TPI/Miniram.
When I had a 305, I was getting 22mpg with my carb. With the 355, it's 19 highway. About 9 city only. 14/15 combined.
#58
I converted my car from an LG4 to TPI, actually purchased a wrecked TPI car and did the conversion right. At the same time I also installed the SLP headers & cat-back, and I went from a 2.73 gear to 3.73 gear IIRC all at the same time. I did not notice a huge change in MPG...
oddly enough, when I went from the stock Formula Wheels & 245 tires, to the 17" ROH wheels with the 275 & 255 tires, I actually noticed a change in MPG. Never could figure out why... but it seemed to happen at the same time... Of course I have messed with my PROM and made it more on the end of performance, over the original 87 PROM that was for economy...
#59
I do find it funny, my carbed 84 still gets better gas mileage on the highway than either of my other two DD vehicles (Avalanche/Explorer).
#60
The car with the 4BBL really was not that bad for fuel economy... If I was really worried about it I would stuff the 86 PROM I found in a junkyard... Buuut I like pull too much...
#61
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Last figures I recall on my 305 TPI A4 ... 18 mixed and solid 25 hwy, no AC as it currently doesn't work. Driving gingerly with a few spirited bursts here and there.
#63
The 383 powered GTA in my sig gets 26-28mpg on the highway depending on weather and status of my windows and T-tops. T-tops being out has seemed to cost me nearly 3 mpg at times.
Mixed city and highway I'm 18-22 depending on the mix. As others have mentioned the T56 helps. Also helping me is a good combustion chamber, 10:1 compression, .040" quench, and a mild cam.
#64
#66
The reason why the manual is more efficient than an auto is how the auto works. There are more internal frictions and that leads to more losses of power thru heat. A Manual is more or less direct drive once you let off on the clutch.
Also with an Auto, you are still spinning the torque convertor when you let off the gas, they do not coast quite as well as pushing in the clutch. I know at first my torque convertor Stall was stock, I could barely stop the car, I had to stand on the brake. I changed the stall to 2000RPM convertor and it really made it easier to drive...
#67
Michael
#68
Sorry it took so long to get back here... There is plastic ductwork that comes from where the foglights are usually mounted. If you pop the hood and look under your two square air filters are, you can see it ..and in mine there was a little hole in each one. You cut that ductwork to divert more air to the air filters. They almost act like mini air dams. I would say that you could just take the connecting piece of ductwork out, but then you'd have to worry about picking up trash on your radiator. I'll post a picture in the next couple of days, because it's kind of hard to describe.
I regularly make a run from Atlanta to East Texas, and yes, my average gas mileage is 33 mpg. I'm not sure how much affect the type of gas has on it, but I only run Shell gas in my cars. Ran some cheap racetrac gas in it once, and the gas mileage was horrible.
Michael Carter
#69
Car: 1983 G20 Chevy
Transmission: 4L60
My cammed 305 Tahoe with a 4L60E and 3.42s rolling on 85 lbs each 305/50R20s on 20x9.5 wheels would knock down 22-23 mpg highway and about 14 in-town.
My Express van with a cammed 5.7L vortec with tri-ys consistantly saw 18-19 mpg running 80 mph on the highway with 30.5" tall 20s, 4L85E and 9.5" 14-bolt with 3.73s. 350 was spinning about 2,500 rpm @ 80. About 12-13 in-town. I ran a Holley 650 double pumper spreadbore carb on the L31 in that van for a year as well. Roughly the same fuel economy as the EFI setup.
#70
Car: 1983 G20 Chevy
Transmission: 4L60
#71
2nd gen Camaro here.... ZZ4 350 with a Miniram, 212@.050 cam, AFR 180 heads, putting out about ~400 hp, TH700R4, 3.42 axle ratio, and highway mode lean-cruise activated, I was getting ~27-28 mpg highway cruising along at 75-80 mph. After I added the Gear Vendors overdrive unit to the transmission, the double overdrive increased my mileage to 29-30 mpg highway.
Around town if I drive normally I can get ~14 mpg.
When I had a carb set up in the early 1990's and the TH700R4, I could pull down 21 mpg on the highway, but was only getting 10-11 around town. It was a mild setup though.. Edelbrock Performer manifold, 600 CFM carb, and a cam about the same size I'm running now.
#72
Car: 1983 G20 Chevy
Transmission: 4L60
Was running at about 2,000 rpm and roughly 40° of timing advance. Q-Jet is way more efficient at light part-throttle. At 2,000 rpm no load the Q-Jets primary main metering is atomizing fuel very nicely in a fanned out mist similar to what a TBI looks like and the edelbrock is merely drizziling huge droplets in.
