high mileage tpi engines
1 Post
Car: 91 gta ws6
Transmission: 700 R4 TRANS
for those out there with 3rd gens fbody that has tpi sbc of any sort in their cars with over 140,000 miles on there what type of engine oils or additives are you guys using to keep your engines running at its best or alive.
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Re: high mileage tpi engines
I prefer penzoil 10w40 std oil for high mileage engines, but thats me
You'll want to step up weight slightly to account for the extra wear. Biggest thing is to avoid switching oil types
BTW, 140,000 isnt high mileage. Post back once you crack 200,000
Car: 91 formula
Engine: 350 tuned port. bolt ons
Ive always use standered castrol. Had 170k on my old gta. The best oil is clean oil. Alot of people think they can use syn and run a year without changing the oil. Ive never had any problems running just reg motor oil in all my third gens.
1 Post
Car: 91 gta ws6
I have heard that its good to mix synthetic oil with regular for the high mileage engines.next i heard about the zddp additive for motor oil.
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
I've pulled several tpi motors from parts cars, only one had real engine issues, thrown rod from a high school kids 350. Most of the others had between 150k and 190k and looked very clean in the bottom end.
Sbc's are pretty durable in stock form and easy on the oil. I see no need for syn , just change it regularly.
Car: 92 Firebird
My original trans gave up around 260some, completely worn out engine was pulled at 296k for a LSx swap. In hind sight I should have done it 6 months after buying the car
If you're considering a swap in the future, start gathering parts NOW and avoid the 1-3 year build threads like most people have. My first swap took 5 days and my second 16 hours. You will NOT be disappointed
My 91 Z28 has 212k on her and it shows, It blows alittle smoke on start up but drives around just fine. I'm pieceing together a new LQ9 with an LS3 top swap and a 4L65E with paddle shifters . So it won't be long before the treefiddy goes byebye lol.
Car: 1991 Z28
Engine: 350 TPI RAMJET COMING
Depends modern oils don't break down. What they do it pick up containments. If your fuel injection works spot on an you keep up with regular maintence......250-300K isn't a problem these aren't high reving motors. My father worked for Shell oil co for 25 years and i worked around and managing quick servs for 7 years......I have my on views but thats another subject.
1 Post
Car: 91 gta ws6
Car: 92 Firebird
Smoke on start up is usually worn valve seals, mostly an age and wear issue. Can be addressed in an afternoon
Smoke during acceleration usually means worn rings, the engine requires an overhaul
I've only had the car for about a year and it's done it ever since I bought it. The previous owner was an idiot when it came to cars (says his father) I found so much stupid stuff done to it like duct taped vacuum lines and about 15lbs of speaker wire stuffed from the engine bay to the rear of the car lol.
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Addressing the ZDDP comment from above...
ZDDP is really only needed if you have a flat tappet cam, which would be found in pre-87 SBCs. Even then, there is debate as to how much it's needed. I'm on Wrangler forums as well, as I own a 99 Wrangler. The old Jeep I6s were about the last engines I know of to run flat tappets...the vast majority of them run normal oil without special ZDDP additives. Most never have an issue.
With that many miles, I would say conventional oil is fine. I run Mobil 1 in my IROC, but it goes 600-700 miles a year and gets changed once a year. With 23,600 on it currently, I am at the opposite end of this discussion
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
I just bought a 1991 GTA with 314K miles. Was told it has had one engine rebuild by previous owner. Not sure miles since rebuild. Runs good no blue puffs on start-up or under hard acceleration. These were not hard miles but that is still a lot of miles would not you say.
1 Post
Car: 91 gta ws6
Well thats what i am hopping that my motor can last for at least 250,00o to 300,000 miles that would be great.I just had the head rebuilt.so that way it would save me the hassle later on down the road
160k on my old L98 before pulling out for 383. I used standard 10w30's. Cam bearings showed wear by that point. Looser timing chain too. Didnt get to see the crank main bearings or rods but likely had some wear. Solid oil pressure tho and never had blowby or smokey starts. Ran 12.9's with just bolt ons at 160k miles so i say it was running tip top
Mine died at 167,999...either leaked or burned oil, previous owner never checked or changed it and ran it dry until it seized.
Probably would have gone another 100k if the moron just bothered to check it every once in a while.
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
I got about 250,000 miles on my original 305 TPI and run Castrol Syntec 20-50 and it does fine. I drive the crap out of it everyday to haha (rpms on average stay at 3000-4500 when gettin thru traffic and taking off), and I run it to 0-120 once a week just for fun
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
i only have 123k on mine, the highest mileage one I had was like 180k and it ran just fine. I used Castrol High Mileage in it and Lucas. helped with the start up smoke
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Mine had 200K miles on it when I sold it..... (yeah, I no longer own a third-gen, I just miss this place, and my car...) Had 88K when I bought it. Regular oil changes and maintenance, dino oil, no additives at all. Original engine and trans. All I did was change the valve seals. Didn't use oil, ran great.
My 305 TBI RS had almost 400,000 miles and was running well before the LS swap.
The TPI cars can also do some serious miles. Sadly, these two aren't on road now but 360,000 miles and 275,000 miles is hard core longevity. If only had the funds to restore and repair. Bet this car could see 400,000+ miles.
This car looks restorable to me.
Car: 1991 rs, 1985 z28
Engine: 3.1 v6, 305 tpi
Transmission: 700r4, 700r4
Axle/Gears: 3.23, 3.23
I ran regular walmart high mileage supertech oil when i bought my 85. Now i run castrol gtx ultra clean with a zinc additive. Runs strong, not sure how many miles since my odometer is broke. Found a shop receipt from 2010 that showed 89,000 so my guess probably 130,s now.
Car: 89 Firebird
Engine: 355 TBI
I sold a 91 Z28 Lb9 car when it had 180k or so mi. Found it a year or so ago it was wrecked but the engine still ran at 322k mi! I ran it hard when I had it to say the least, I was 21 when I bought it and maybe 25 when I sold it.
The_Phoenix
09-03-2015 10:56 PM
R3500
08-17-2015 12:16 PM
Sanjay
08-12-2015 03:41 PM
