Replacing Head Gasket
Old 07-31-2013, 07:54 AM
rwstegne's Avatar
Car: 1989 Iroc Z 5.7L
Engine: 5.7L
Axle/Gears: built 4.10s
Guys, here are a few pictures of the top deck of my block. Plan on running replacement composite Jegs head gaskets but am worried about the discolored pitting around the water jackets. Any advice on what is acceptable or not because I can’t find any good videos online.Replacing Head Gasket-dsc05663.jpg
Old 08-02-2013, 03:04 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Replacing Head Gasket
The deck on my rebuilt shortblock was a little discolored here and there. If it's straight and you don't want it decked, they just clean them up and call it good for a daily/mild perf. usage. As long as it's straight, a little Scotchbrite and brake cleaner will put you right in position.
Attached Thumbnails Replacing Head Gasket-dscf1851.jpg   Replacing Head Gasket-dscf1852.jpg
NinjaNife
08-23-2015 11:49 AM
lakeffect2
08-23-2015 08:44 AM
NWAsonoma
08-18-2015 05:45 PM
MY87LT
08-17-2015 08:43 AM
Quick Reply: Replacing Head Gasket
