Code 24 w/ Autometer setup
Car: 1987 IROC-Z Camaro
Engine: 305 LB9
Car is an 87 iroc lb9 700r4 with cable driven speedometer. I'm getting code 24 because I have no speedometer (I am converting to autometer), wondering if its possible to run an autometer speedometer without triggering code 24 & if so what else do I need besides the speedometer itself?
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: Code 24 w/ Autometer setup
anything is possible, you will need an electronic speed signal from the transmission you may need to go in to a dakota sgi box to output 2k pulse signal to the computer and a pulse to the electric speedometer.
Engine: 305 LB9
Would I be better off ditching the cable setup and switch to electric signal? Is this
http://www.dakotadigital.com/index.c...roduct_id=126/
the dakota box you were talking about?
