Tpi 350 no injector pulse on drive side
I have a 92 z28 camaro 350 tpi and the drive side injectors are not pulsing it started doing it a little at a time then it would go away the it went completely out and is only running on four cylinders
Car: check
Engine: check
Transmission: check
Re: Tpi 350 no injector pulse on drive side
Under the dash in the fuse block, check the two that are labeled INJ1 and INJ2 (10A).
At the ECM check the terminals/wires at pins C11 and C12.
RBob.
RBob.
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
