Is there a difference between pre-90 tpi intake and 90-92?
Old 09-30-2015, 05:47 PM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
Besides cold start and maf/map. Can they be interchanged? Also, where is the map on a 90-92 located? Anybody have a pic? I have a base,runners and plenum and want to know what year it's from.
Thanks.
Old 09-30-2015, 07:44 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: Is there a difference between pre-90 tpi intake and 90-92?
Interchange - the parts will all bolt up, but there are some functional differences.
Plenum - 89-92/SD has 3x ports (vs 2x on 85-88) on the rear passenger side, along with a boss to bolt the MAP. Look at the bottom of the plenum... MAF has a cast passage from the TB to both sides, while a MAP has a single (EGR) passage cast to the passenger side.
Runners - passenger side is identical for all years. The driver side does not have the 9th/CSInjector, not the corresponding tube from base to plenum.
This has some comments and pictures from here.
MAP...
1992rs/ss
05-19-2020 07:02 PM
evilstuie
01-09-2020 08:29 PM
masonta
08-31-2015 10:14 PM
Sanjay
08-12-2015 03:41 PM
squiggy2
08-09-2015 09:30 PM
Quick Reply: Is there a difference between pre-90 tpi intake and 90-92?
