MAF airflow wire
MAF airflow wire
I am I assuming right that the mass airflow burnoff black ground wire send power to the mass airflow black ground to power it? I check the black ground wire from the ECM back to the mass air flow black wire and did not get a reading. So that tell me that it is a break in the wire correct?
Engine: 4++,350 & 305 CIs
Re: MAF airflow wire
Ground wire shouldn't have power
The 1st post is hard to understand exactly. I get what you are saying now.
What kind of reading are you looking for on the ground wire? continuity ?
If the ECM isn't closing the relay, you won't have continuity..
Vader I pulled the ECM harness and the MAF harness. I probe the black wire on the MAF wire harness and the black wire on D12 from the ECM harness. I set my DVOM to continunity where it beeps to see if there was a break in the wire. I did not get a beep so I am thinking there is a break in the black wire. I am on the right track? Thanks for everyone help. I will get it straight soon.
The black wire ("B" terminal) should have continuity from the MAF connector to the ECM connector (D12). You may have discovered a problem. I don't believe there are any other connectors in the circuit aside from those two.
Vader yes that is what I am talking about. There is no continuity from the black wire ("B" terminal from the MAF connector to the ECM connector (D12). So is that is a break in the wire?
UPDATE: TTop and Vader thanks for all of your help. I replaced the black wire from the mass airflow harness to the ECM wire. Turns out that help with my hunting idling issue. I am still getting the code 33 and 41. I will address those one on one.
Car: 1989 GTA
Engine: 5.7 TPI
Axle/Gears: 3.27 (Stock)
When I was having MAF code issues I came across a hard to diagnose issues. I had all the power and continuity I should have, tried a different sensor etc. In the end my issue wound up being the connector at the MAF. The pins had been widened, probably from years of removal and reinstall. The springy parts of the contacts were not contacting the pins on the sensor any longer. A small pick and some tweaking on those on the connector itself and everything was good to go again. Just something worth checking.
