View Poll Results: what should i do
get a th 350
0%
add to the th400 i already have
100.00%
Voters: 3. You may not vote on this poll
i am in a pickle of a situation here
Old 04-14-2003, 09:21 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
alright guys i have a debate here. i have my 383 in the sig below and was going to put in a th350 beefed up behing it. well i do have a th400 that i took out of the elcamino and it looks to be in good shape. when the pan was removed it was surprisingly squeaky clean. should i throw in a shift kit and a convertor in the 400 or save up and get a new 350? and if i go with the th400, i need a driveshaft from a 200r4 correct? does anyone know how long that driveshaft is since i have 4 driveshafts laying around?
Old 04-14-2003, 09:34 AM
1986redbird's Avatar
it is my impression that the TH-400 is the stronger unit, I believe that they were used alot behind big blocks and in heavy duty trucks. it should be the better of the two, as far as driveshafts go, I don't have a clue but I'm sure that someone else will chime in here.
Old 04-14-2003, 01:01 PM
cashman's Avatar
hmm, i think the driveshaft should be the same lenght as the 700r4, its the th350 that needs a longer shaft(i did the 700-th350 in my 89 rs) and the 200 will fit the th350, not the 400, u should be good
Old 04-14-2003, 02:39 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
and another question, has anyone attempted to make the torque arm mount rather than buying? i have some spare metal and a welder i was thinking it might not be to hard. any thoughts. if it doesnt work i will just buy it.
Old 04-14-2003, 05:10 PM
cashman's Avatar
i was lucky enough that the tailshaft off my old 700 worked and i didnt need one, though i only have about 1/4" of torque arm, if anyone knows where to get torque arm mounts for th350 send me an email
Spyder_TheGamer
10-02-2015 12:25 PM
skinny z
Carburetors
09-29-2015 11:25 PM
drumstixer
09-29-2015 03:02 PM
tuningnewb
09-23-2015 07:06 PM
327IROC85
09-23-2015 12:11 AM
Quick Reply: i am in a pickle of a situation here
