Tranny slipage
Old 06-10-2005, 09:52 PM
IROCmenace's Avatar
Car: 1988 IROC
Transmission: 700R4 Silver Dart
Axle/Gears: 3.70 posi
Tranny slipage
Just got this car. It is an 88 305TPI IROC with a 700R4. It drives great but the tranny slips. The detent cable is probably screwed but I was hoping you guys could help in diagnosis
When I drive the car and floor the engine revs as though the trans is slipping in and out and then catches and the car takes off
real hard It also does this at part throttle but not as violent. The converter locks up but takes a little longer to do than my Formula and the Formula runs great. Could it be the TV cable
or is a better bet that the tranny or torque converter are shot? Would low fluid or nasty fluid cause this? By nasty I mean the 170K mile original nastiness is how it looks!
Old 06-10-2005, 11:49 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Check the fluid level, and smell of it, see if it smells burnt or not.
Old 06-10-2005, 11:52 PM
IROCmenace's Avatar
Car: 1988 IROC
Well hello to Kingsport. I'm in the 'boro. Thanks for the reply I will tomorrow. You think that could cause the problem? I know it can't help.
Old 06-10-2005, 11:56 PM
Engine: 383, L69
Good to see someone else from NE TN. Yeah i think that could be your problem, check that, and then adjust the tv cable.
Kevin
Old 06-11-2005, 12:33 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
I agree. If it smells burt, put a fork in it.
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
bjpotter
10-04-2015 07:48 PM
Stryker412
09-07-2015 09:11 AM
apie2546
09-05-2015 07:40 PM
IROCZ1989
09-04-2015 11:54 AM
Quick Reply: Tranny slipage
