stall converter
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
stall converter
hey guys i need a new converter mines ticking, second time this has happened. so im going to buy a new one i have a pretty stock 305 with a 700r4 mated to it i was wondering if i could run any type of stall or would i have to stick to stock would there be any benefit of running like an 1800 stall?
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: stall converter
A GM S-10 (small pickup) converter works beautifully behind a stock LG4.
It's about a 2000 stall compared to the stock ~1400 stall.
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Re: stall converter
yeah a 2000-2200 would do great in a stock setup like yours.
Car: 89 chevy camaro rs
Re: stall converter
i just put a 1800 stall in my 305 and its awsome its still almost as quick as when i had 3000 stall a few weeks ago
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
Re: stall converter
ok cool, so does anyone know why my TC is ticking like this, this is the 2nd time this has happened.
Re: stall converter
take video of it,it could be the frnt pump too
only way to really check the converter is to have a preasure check
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
Re: stall converter
http://www.youtube.com/watch?v=76CVw9zsxZQ
here's the video i took today. the ticking comes and goes but pretty much always sounds like this while in park. i dont know if somethings loose or if its the TC considering last time i went on a hunch and changed it and the noise quit. i just dont want to keep doing this theres got to be a culprit here.
Engine: 4++,350 & 305 CIs
Re: stall converter
Make sure your flexplate isnt cracked around the bolt holes on the crankshaft
Re: stall converter
sounds to me line bad flexplate or loose converter bolts. ive had bolts loosen before not long after putting a converter in maybe check and make sure none are loose.
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
Re: stall converter
ok guys i really appreciate the quick responses im off tomorrow so ill go ahead and get under the bow tie to check the flex plate and bolts. i really hope thats the problem cause i don't want to take that transmission out again it'd be the third time in a years time. unless of course its the flex plate, this thing that gets me is it doesnt do it all the time and it is rpm sensitive up until about 2500 then it goes away maybe the G forces are pushing hard enough to keep whatever is moving still? just a thought
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
Re: stall converter
Just wanted to say thank you I pulled my trans. Last night to find that the flexplate was cracked all the way around the crank bolts and in danger of completely separating. Which it did when I pulled it off. All is well now got the new one up in there and she's running like a champ, once again thanks for the suggestions
Re: stall converter
glad you got it fixed i went through issues and sounds like that a few times with diff vehicles.
Re: stall converter
Glad to hear it was a easy fix.. I've changed a ton of those flexplates in my cars for the same thing,they just arent strong.
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
Re: stall converter
well guys it was kinda fixed keep an eye open im starting a new thread
Hotrodboba400
12-10-2019 07:07 PM
MikkoV
09-09-2015 04:25 PM
