NEED TO KNOW IF SWAP WILL WORK!!!
Old 12-02-2011, 03:31 PM
skully-bones 13's Avatar
Car: 1985 Camaro IROC-Z
Engine: 305 w/ 4 barrel carb
Transmission: brand new 700r4
my rear end basically ate itself the other day, the seal was just changed but i spose it was defective and all my gear dope leaked out, so we scrapped the axle because the spider gears shreaded.
what i neeed to know asap is, my friend has a 10 bolt axle off of a 78 camaro and i need to know if it will bolt directly on. this car is my DD and i [retty much need to have it back on the road as fast as i can.
please help haha
Old 12-02-2011, 03:34 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: NEED TO KNOW IF SWAP WILL WORK!!!
you need one from a third or forth gen. the 78 is leaf spring.
Old 12-02-2011, 07:18 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Yup what he said. It wont work. You can take a axle from a 4th gen if you dont mind your wheels sticking out a couple inches in the rear too. Id just find a third gen rear and be done with it.
Old 12-02-2011, 08:33 PM
Andrew James's Avatar
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
I would not have scrapped it just due to spider gears... Hell, you could probably have lincoln locked it temporarily if you took turns easy until you had a new axle prepped.
V--1991, street driven mini-spooled truck
Frozer!!!
01-19-2024 04:55 PM
Jorlain
08-24-2022 05:11 PM
jharrison5
08-19-2015 05:53 PM
1992 Trans Am
08-08-2015 08:16 PM
rsrmoore
08-07-2015 08:44 PM
Quick Reply: NEED TO KNOW IF SWAP WILL WORK!!!
