LT1 clutch fork install
Old 07-04-2012, 08:23 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
Do the metal tabs go over the pivot (the side facing us where the head of the bolt is) or under the pivot (away from us, under the pivot)
Old 07-05-2012, 02:59 AM
BrianI's Avatar
Re: LT1 clutch fork install
They go over
Old 07-05-2012, 11:15 AM
jmd
jmd's Avatar
Car: `86 SS / `87 SS
The tangs are bent upwards so it goes correctly over the tee.
Old 07-05-2012, 11:27 AM
Car: 89 GTA
Axle/Gears: 4.10
Yeah, I pre positioned them to go under the pivot so when I got everything together and pushed the fork into place I messed up the clips. Guess I'll be pulling the trans to replace the clutch fork!
Old 07-05-2012, 11:36 AM
BrianI's Avatar
Can u not take the bolt out and then the fork while its still in the car?
Old 07-05-2012, 11:39 AM
Car: 89 GTA
Axle/Gears: 4.10
It doesn't seem possible to me.
I also am having a huge leak on the rear main so need to pull the trans anyways. You could call it luck.
Old 07-05-2012, 11:46 AM
BrianI's Avatar
I see. Your luck is real similar to mine
midge54
12-27-2019 04:14 PM
midge54
01-29-2017 07:00 PM
87 camaro iroc
08-20-2015 07:47 AM
1992 Trans Am
08-08-2015 08:16 PM
rsrmoore
08-07-2015 08:44 PM
Quick Reply: LT1 clutch fork install
