700r4 shifting late
Car: 1986 Pontiac Trans Am
Engine: 5.0
700r4 shifting late
hello fellow enthusiasts im having problems with my transmission shifting late in drive or overdrive i think it has a 700r4, i have already readjusted the TV cable and fluid is correct operating level and clean it does not feel like its slipping and does not shift hard any other suggestions?
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: 700r4 shifting late
Which gears are affected?
MAybe a problem with the governor.
Engine: 5.0
Engine: 5.0
There was a link in that thread with more detail. It's under a dome shaped cover on the side of the transmission.
http://www.dragracingonline.com/tech...vi_9-bm-1.html
Engine: 5.0
thanks ill check it out. but i was thinking if maybe the previous owner added less weights to the governor to increase the shift points already. if this is true would i hurt anything if i just use the car for everyday driving? it has a high way gear in the differential so that lead me to believe somebody altered the shift points. all i know right now is the car is fast lol, and it goes through the gears alittle quicker when i punch it (WOT)
Engine: 5.0
nope never saw Blazing Saddles. i figured the "GOV" on the guys coat meant governor especially since this thread is discussing the governor in a transmission im 28
Engine: 5.0
ok update: the transmission shifts fine from first to second but when it shifts from second to drive it shifts at like 2000 which i know something is wrong any suggestions?
Zeek1041
Theoretical and Street Racing
09-30-2015 11:00 AM
TX-SleeperC5
09-24-2015 03:13 PM
TheTraut88
09-07-2015 05:22 PM
