manual torque converter locking question about wiring
Old 10-21-2013, 09:04 PM
casson4's Avatar
Car: 1985 camaro berlinetta
Engine: carb'd lg4 305
Axle/Gears: 3.08's sonn to be 3.73's
so ive already searched and no one has asked this question, my torque converter has been locking at random points like at 10 mph today, so i want to wire in a manual switch and istill have my stock ecm so can i just do this and will it work the same as all the other ways of wiring one https://www.thirdgen.org/torqueswitch
Old 10-21-2013, 11:27 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: manual torque converter locking question about wiring
Originally Posted by casson4
my torque converter has been locking at random , i want to wire in a manual switch
You can but it won't help your problem if the ECM is locking the convertor now at too low a speed now.
All a switch wired that way does is ADD a manual option , does not bypass the existing ECM control
Instead of shadetreeing the problem, I would be investigating why ?
I would start by checking the tan / blk wire from the trans to the ECM ;if that randomly shorts to ground somewhere it will engage the lockup the same way your new switch would.
Old 10-22-2013, 03:45 PM
casson4's Avatar
K so i was looking at the transmission and theres that wire harness with 2 wires comin out can i just cat those and run those wires to a switch
Old 10-22-2013, 05:35 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Ktheres that wire harness with 2 wires comin out
There should be 3 wires at the TCC plug
What colors are the wires you have ?
Old 10-22-2013, 06:11 PM
casson4's Avatar
my bad i didnt jack it up on jackstands before, i do have three wires theres orange green and purple
Old 10-24-2013, 11:03 AM
casson4's Avatar
can i just have pin b and pin d always grounded and then pin a connected to a 12v source. can i put a toggle switch on pin and just flip the switch on when i want to engage the torque converter
1992 Trans Am
05-10-2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
06-22-2021 08:21 PM
jklein337
09-19-2018 06:23 PM
redmaroz
08-16-2015 11:40 PM
gwade12
08-08-2015 08:17 AM
Quick Reply: manual torque converter locking question about wiring
