Lost Converter Bolt
Old 07-12-2014, 12:29 PM
86purpledragon's Avatar
Car: 1986 Trans Am
Lost Converter Bolt
So this week I was driving along when I heard a loud *tink*. At the time I thought I just ran over a rock and my tire picked it up and threw it into the undercarriage. Well this weekend I finally got a chance to crawl under it and take a look. Immediately I saw a hole in the bottom of the plastic trans/flexplate guard. Upon removal, I discovered one of the trans converter to flexplate bolts is gone. Apparently the threads failed in the converter because now I can't get a new bolt to thread in and get tight, the bolt just catches then lets go and spins.
Its an 86 TA, 350, 700r4, and my daily driver. Any ideas? I know she needs a new converter but I drove for half a week on 2 bolts and it seemed fine. I just don't have the time to drop the trans at the moment, but I'm concerned about putting that much stress on only 2 bolts (plus possible balance issues). Any help would be much appreciated. Thanks.
Old 07-12-2014, 06:48 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Lost Converter Bolt
Pull the trans and replace the converter.
Old 07-12-2014, 07:04 PM
jmd
jmd's Avatar
Car: `86 SS / `87 SS
Pull another bolt. Verify it's M10x1.50 thread.
Get a heli-coil or thread-insert repair kit. You'll need to back the trans. out a bit to get decent clearance for the drill unless you're good w/ a 90deg. adapter.
1992 Trans Am
05-10-2023 07:19 PM
wbrooks63
Exterior Parts Wanted
10-04-2015 08:40 PM
xxx3man`
09-23-2015 10:37 PM
Dialed_In
08-20-2015 01:45 PM
djmarch
08-19-2015 12:07 PM
Quick Reply: Lost Converter Bolt
