Inch size of 88 camaro 700r4 torque converter??
Car: 88 camaro
Engine: 355
Transmission: rebuilt 700-R4
Buying a new high stall converter but says to make sure size is right. The one im looking at is a 12". Is that right? Thanks in advance
Car: 1988 Camaro
Re: Inch size of 88 camaro 700r4 torque converter??
The higher the stall the smaller the dia. size in most cases with torque converters. As long as it fits your 700r4 it does not matter if it's 9" or 13" dia. if it's the stall speed you need.
Car: 88 camaro
Engine: 355
Alright thanks for the reply. Says its a reman with 22-2500 stall. Im installing a 5.3l have a rebuilt 700r4 in it and just wanna get it up to the power range quicker but keep it d/d. And also on a budget
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Most low stall converters (under 2800 rpm) can work fine in a stock 12-13" body. If you need more stall speed, a 10" is most common. My 6000 rpm stall converter is in an 8" body.
Required stall speed completely depends on the cam grind for best performance. Too high a stall can be just as bad as too low.
knight72
08-10-2015 09:32 PM
