Need help 700r4 no forward drive?
1 Post
Car: 83 firebird 500 le
Engine: 350 chevy with 305 heads
Transmission: street/strip 700r4
Axle/Gears: chevy 10 bolt
Hey guys/gals,
I need some help with my 700r4 its just been rebuilt by a reputable transmission repair shop with all new strengthened internals, sonnax and TCI parts new clutches. I have fitted this into my 84 Pontiac and it was working when first put in however it couldn't select 4th overdrive when selected to 4th it was like neutral so I had to drive it in 3rd probably did about 3miles not hammering the trans just babying it along and it gave up all forward drive like it was just slipping slight movement at high revs but couldn't go up hill and you could hold the car still from moving. My first thoughts were the trans cable or shifter were not working but when the shifter was selected it moved the trans shifter lever into each selection, I checked the T.V cable was sweet as as I had fitted a holley geometry corrector, fluid lvels were sweet new trans cooler. The trans only selects park it has reverse but that's it. I have since taken the trans back to the shop they stripped it (air tested it) not sure what that's is? the mechanic said everything looks new and cant find anything wrong with it please help I have spent so much on this trans now im wishing I had gone with the T56 conversion would have been a bloody sight cheaper, any help woul be very much appreciated.
Cheers Nat
Cheers Nat
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: Need help 700r4 no forward drive?
I wonder is a sprag installed backwards
mdtoren
08-16-2015 05:45 PM
