700R4 Speedometer Gear Change
Car: 88 GTA ZZ383
Engine: ZZ383
Axle/Gears: 9 Bolt with 3.73
I have an 88 GTA with 700R4 and Borg Warner 9 Bolt 3.27 (GW6 code). I just rebuilt the rear end and changed gears to 3.70. Does any one know what size speedo gear I need to calibrate my speedometer with the new gears. Tire size is 255/50 16R. Thanks
Re: 700R4 Speedometer Gear Change
You need to know what speedometer gears are in the tanny now then use the speedo calculator in this site and order gears. http://www.transmissioncenter.net/sp...__va.htm#700r4
This may help.
ambainb
04-25-2016 09:21 PM
