in need of a 2.29 10 bolt gear set
id anyone has a set of used or knows were to get a set please let me know
this is a gm gearset i desperately need a set for boneville as my 3 spd and 2:73s arent going to cut it
Re: in need of a 2.29 10 bolt gear set
Not sure if these will do it but
http://www.ebay.com/itm/V8-Monza-Vega-2-29-7-5-10-bolt-POSI-sunbird-skyhawk-2-2-mirage-2-series-GM-/221815482590?hash=item33a53ba8de&vxp=mtr
http://www.ebay.com/itm/GM-CHEVY-7-5-7-625-10-BOLT-RING-PINION-2-29-1-GOOD-USED-OEM-CAMARO-FIREBIRD-/151600990822?hash=item234c1f8a66&vxp=mtr
I can vouch for Monzaz. The first ebay listing posted. I think the pinion bearing is different from our fbodys and the h body 7.5" gears.
You can send him a message and he will tell you what it will take to make it work. In my vega it requires an fbody pinion to be turned down or the bearing replaced with an alternate to fit into the housing if I remember correctly.
also came up with some 2:41 and 2:14 gears on another forum , though the 2:14's are way to steep
Received 1,672 Likes
The pinion bearing is different on the pre-80 7.5"s; but the pinion is the same. Outer race dia is what's different.
trying to keep from spinning the motor that hard i was thinking the 2:29's and a 26 inch tire
its not looking good for speedweek this year though due to the condition of the salt , so im currently focusing on the silver state classic
AFAIK the only difference in the older 7.5" and the 80-up version, is the pinion head bearing OD.
AFAIK all 7.5" pinions fit all years of housings.
AFAIK also there's no internal difference between F body 7.5"s and any other.
only one way to find out and thats to run it, hoefully my fti converter doesnt have a ton of slip in it but im trying to go for the th350-2.29 gear - 26 inch tire combo. this will be my first time doing this so im not expecting to have a great outing im sure i have alot to learn about lsr main goal at this point is give it an honest try and have a blast doing it
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
red90IROCls1
08-25-2015 06:56 AM
