88 iroc auto trans
Old 08-05-2015, 08:06 PM
Leggman1's Avatar
88 iroc auto trans
I have been working on this 88 iroc that I got real cheap because it had issues.
It is a stock 305 with a auto trans.
The cooling fans didn't work so it ran hot, It had a cracked flexplate, And the back brake lines were rusted out.
First I fixed the main cooling fan by replacing the motor, I replaced the flexplate with a new one and when I filled the trans I put in the 10 pints the book called for but it wouldn't register on the stick. I ended up putting in two gallons just to get to the full mark on the stick. Now I am questioning that thought process because I have a big puddle of trans fluid on my floor. I am thinking the guy that had it before me put in the wrong dipstick???
How much fluid is needed for a 700r4 trans???
I did replace the dipstick tube seal when I had the trans out. I can't really tell where the fluid is coming from. Please help and Thanks Dave
Old 08-05-2015, 10:09 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: 88 iroc auto trans
In general, the fluid capacity of a 700R4 is about 5 quarts with a pan drop and filter change. Total capacity is about 11.5 quarts.
If you left the converter in place - I don't see why you would need to remove it from the transmission for a flex plate change, I would say it's now over-filled.
Old 08-05-2015, 10:24 PM
Received 1,672 Likes on 1,269 Posts
10 pints (5 qts) is correct. Different cars, depending on the angle they sit at, vary a bit; but never more than a qt or so.
I'd say yours is (was?) overfilled at this point.
Might want to drop the pan, let it drip overnight, put the pan back on, put 4½ qts in; and mark your dipstick at that point. DO NOT do this by scribing a mark across it; look up how to cut glass (if you don't already know how) to see why. Instead, drill a small hole, like 3/64" (.050" more or less) or so. Then add another qt and drill another hole, there's your empty <-> full range.
Old 08-06-2015, 04:15 AM
Leggman1's Avatar
Cool Thanks
BlueIroc-Z
06-09-2019 03:22 AM
84z96L31vortec
08-20-2017 12:16 AM
Exxon Limited
Camaros Wanted
22
12-21-2015 10:36 PM
mustangman65_79
08-11-2015 03:17 PM
84z96L31vortec
08-10-2015 08:27 PM
Quick Reply: 88 iroc auto trans
