3/4 clutch apply plate missing
Engine: 305 tpi
This transmission I am rebuilding is missing the thick 3-4 clutch apply plate that sits directly on the 3-4 clutch retainer with the little tabs in the input drum.
It was apparently rebuilt by a reputable company back in '08.
Does anyone know why/how it would have been built without this? I'm just curious on whether it was intentional or not...I imagine not.
Car: check
Engine: check
Transmission: check
Re: 3/4 clutch apply plate missing
This is just a wild *** guess, maybe to allow more plates to be installed?
The 3/4 clutch stack up in the 700R4's can be varied according to how the trans is to be used. Thicker and fewer clutch & plates for road use (to dissipate heat build up), to using more and thinner ones for drag use (for better power transfer).
RBob.
RBob.
The 700R4 uses the thin .055" apply plate with five fingers and it uses the .125" - .130" flat pressure plate that sits on top of the thin .055" plate. This is fine and I use this setup all the time without problems. Starting in 1993, they went to the "one piece" apply plate. You can use either one here without any problems.
Engine: 305 tpi
1992 Trans Am
05-10-2023 07:19 PM
theshackle
09-17-2020 08:26 AM
mhatfield 14
10-24-2015 07:48 AM
