9 Bolt Posi Rear Disc parts identification
Car: 1989 Trans Am
Engine: 5.0 TPI
Axle/Gears: 3.45
I am rebuilding a 1989 9 bolt rear axle from a Formula. It has disc brakes on back and I need the emergency brake cable return spring. I can't find a diagram but I did see a few different pictures like the one shown. I have the same brakets. Is this type spring what I need for a 1989? does anyone know of a part number?
Rick
Rick
Engine: 4++,350 & 305 CIs
Re: 9 Bolt Posi Rear Disc parts identification
I don't have a part number but that spring was used from 89-97 and may be included in (small parts kit) for the calipers.
I have never seen those for sale separate. I would look on rock auto and see if it is in any pictures. I know the 84 10 bolt coil style I searched for endlessly and could only find them pre installed on new calipers. I ended up getting some used ones from a part out on the board.
May take awhile to get them but looks like he'll sell them separate.
http://flynbye.com/catalog/i233.html
Car: 1989 Trans Am
Engine: 5.0 TPI
Axle/Gears: 3.45
Thanks. I did leave a message with them but no return call. I do have a GM part number but no luck so far 18020429 RR Parking Brake Lever Return Spring
Car: 1989 Trans Am
Engine: 5.0 TPI
Axle/Gears: 3.45
Thanks for the help on this. I got a used set of calipers off a 94 parts car real cheap.
jtrusso
08-25-2016 09:49 AM
