tire size
Car: 1988 IROC-Z
tire size
I have a 88 IROC-z with 15 inch rims in the back. I was thinking of putting drag radials for the back. But I not sure its going to fit the tires are BFG's the size they have is P275/50R15 or P275/60R15 I was wondering if any of these tires would fit. This is with the stock application. One more question do you know if you can fit 4th generation tires on a third gen car. Thanks
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: tire size
you can run 275/60's on stocker wheels, look in my sig, that what i have on my back wheels. i, however, would recommend going to an 8" wide rear wheel to run these things as the side wall has a lot of slop in them and they will not handle well at all. the 275/50's are 2" in diameter shorter than the 275/60's and i don't imagine the sidewall being able to go to the 7" rim very easily.
Car: 1988 IROC-Z
Thanks mw66nova, so you use the same tire size and BFG drag radials? I thought that the width of a 15" was 8.5" not sure. Thanks. 255/60 works on my camaro right know and it clears it shouldn't be a problem.
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
Originally posted by mw66nova
the stock 15" wheels are 7" wide. i am running some of the new m/t et street radials on them. they are 275/60/15's.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
275-60-15 are too tall and too wide for a thirdgen (you can run a wider wheel, but not a tall tire like that).
They do have a 235-60-15, which may not be as wide, but would work a lot better.
1 Post
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
I thought you could use a 4thgen wheel but the offset was wrong?
I remember reading somewhere that you were good to go with a set of spacers.
I KNOW I've seen them on many cars here. Along with C-5 wheels too.
Hotrodboba400
12-10-2019 07:07 PM
TheTraut88
09-07-2015 05:22 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
