17" x 10" wheels in the back.. lotta questions
Old Sep 4, 2002 | 09:31 PM
CaysE's Avatar
I think this is the size I want to go with for the rear. Tire size 255/45ZR17. The only thing is, I don't know how to determine if a certain rim will fit or not, without sticking out too far or rubbing something in the well. How do I figure this out without having the rims in hand? Also, for anyone running 17s, what width do you have up front? I'm thinking of sticking with 8", but has anyone gone up to 9" without problems? Can the car be lowered at all after this (future plans for 1" drop all around)?
Old Sep 4, 2002 | 11:24 PM
demonchild's Avatar
Its your car. The wheel wells should be big enough all around. If you think it looks good, then it doesnt matter what others have. Go with the size of rims you want.
Old Sep 5, 2002 | 10:32 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I am running 275/40/R17's all around with a 2" drop. I do have rubbing issues up front with the 9" rims. I am still working on that though.
11" rims out back is possible with some cutting, banging, and relocation. Check out www.ws6.com for details on that.
Old Sep 5, 2002 | 04:44 PM
mult68's Avatar
Car: 1992 Chevy Camaro RS
that sure seems like a lot of work to make clearance in the rear...but seems like its well worth it....those big tires look great back there...think its possible on a thirdgen? I would assume so...hmm...ideas
Old Sep 5, 2002 | 05:49 PM
Grey Goose's Avatar
Car: 1990 RS
Engine: LO3 TPI
Transmission: W/C T5
I have 18 x 8.5’s in the front with 245/40-18’s and in the rear I run 18 x 10.0 with 295/35-18’s. The only major modifications were beating the sh*t out of the inner fender panels and cutting and rolling the rear quarters. Trust me its well worth it!
Attached Thumbnails 17" x 10" wheels in the back.. lotta questions-dsc00142s.jpg
Old Sep 5, 2002 | 06:03 PM
CaysE's Avatar
OK, am I doing something wrong here? The tire measurements are wrong on either my end or yours. If I'm correct, shouldn't 245/40-18's be used on 9.5" rims? And 295/35-18's should be on 11.5" rims?
This is the equation I'm using:
mm / 25.4 = inches
or
295 / 25.4 = 11.6
Old Sep 5, 2002 | 06:17 PM
5L EaTeR's Avatar
nope.
ive got 17x9.5's (275/40's) up front and 17x11's (315/35's) in back and have a 1.5" drop (eibach prokit). all i had to was hammer out the fenders and roll the lip also. im thinking of trying to squeeze 335's in back but i dont know if i want to hammer it out more yet...
Old Sep 5, 2002 | 06:24 PM
Grey Goose's Avatar
Car: 1990 RS
Engine: LO3 TPI
Right On 5L! As far as maximum sizes go 285 will tuck nicely in the front with the same modifications and a 335 will tuck with a wide body conversion which basically flaring the quarters or rounding out the outer lips (body work is necessary).
Old Sep 5, 2002 | 06:53 PM
CaysE's Avatar
OK, now I have to start all over again. Someone explain to me the tire measurements, cause on tirerack.com they tell you to divide the first number (255) by 25.4 to get the width in inches (~10").
Old Sep 5, 2002 | 07:17 PM
Grey Goose's Avatar
Car: 1990 RS
Engine: LO3 TPI
To be honest with you, I liked the wheel and tire combination so I was willing to do whatever it took. These wheels were originally designed for a BMW fitment. I had to have custom spacers made for the front (8mm), seal the center cap to the wheel, and remove my grease caps to get the front wheels to seat properly. As for the back I run (12mm) spacers but that’s only because I was obsessed with making the rear wheels flush with the quarters. Now I was in the wheel business back then and had both time and plenty of wheel and tire combinations to play with. So that’s how I eventually ended up with the sizes I have now. Even though the front will tolerate a 285 I run a conservative 245 because it makes the *** end look wider going down the street. My recommendation is a 9” wheel with a 275 all the way around. Staggering sizes looks bitchin but remember you won’t be able to rotate anymore. Good Luck!
Old Sep 5, 2002 | 10:58 PM
CaysE's Avatar
I still need to understand how the tiresizes work. Apparently, I got it all wrong (along with tirerack.com, if you're correct). Someone please explain the tire measurements.
Old Sep 6, 2002 | 08:06 PM
Amrish's Avatar
Hey reddrocket...
Got anymore pics of ur car form different angles? I really wanna see those wheels, they look damn good as well as ur car
Old Sep 6, 2002 | 08:13 PM
Grey Goose's Avatar
Car: 1990 RS
Engine: LO3 TPI
Sure!
Old Sep 6, 2002 | 08:19 PM
87 B4Z's Avatar
ReddRocket, are those speedline wheels? my friends has some rims on his M5 that look just like those and they are speedlines
Old Sep 6, 2002 | 09:07 PM
Grey Goose's Avatar
Car: 1990 RS
Engine: LO3 TPI
Yes sir they are Speedline Type 2310 SC
Old Sep 6, 2002 | 09:14 PM
87 B4Z's Avatar
i thought they looked very familiar
Old Sep 6, 2002 | 09:19 PM
Grey Goose's Avatar
Car: 1990 RS
Engine: LO3 TPI
Attached Thumbnails 17" x 10" wheels in the back.. lotta questions-speedline.jpg
Old Sep 6, 2002 | 11:59 PM
silverstreakII's Avatar
tire sizing
you are correct about the 25.4=1", however the measurement that refers to is the section width of the treadpattern, not reccommended rim width. fyi, a stock iroc rim is 16x8, mounted on 245/50/r16's. generally, you can fit up to a 285 on an 8" rim, but you start getting into the rounded tire sidewalls, bulging out from therim. to keep yourself in the square section, tryi and keep about 1.5" difference between rim size and tread width, particularly with shorter sidewalls. on a 17x8.5, use a 245 or 255, conmsidering the -45 series sidewalls. on a 17x10, to keep the square look, youll have to stay in the 305 range, and to keep stock circumference, youre looking at 305/35/r17, expensive tire. the front, you can use 245/45/r17, and those will fit under the fenders. the rears might require work to fit under the well. to keep a 10 inch tread all around, you could use 245/45/r17 on a 17x8.5 rim with no problems. hope that helps.
ssII
Old Sep 8, 2002 | 11:23 PM
RallyRedTexan's Avatar
Car: 92 RS
Engine: 5.0 TBI
Transmission: A4
What tires are those Red Rockett?
Old Sep 9, 2002 | 12:01 AM
vortechLT1's Avatar
I could be wrong but the tread pattern on his tires look like a brigstone, am I right? they could possibly be a toyo proxys but I doubt it it does look more like a brigstone potenza
Old Sep 9, 2002 | 01:14 AM
TTA155's Avatar
Bridgestones....
Take a look at this image...I increased the brightness, cropped the photo, and rotated it 90 degrees CCW:
Attached Thumbnails 17" x 10" wheels in the back.. lotta questions-bridgestones.jpg
Old Sep 9, 2002 | 06:14 PM
92Z's Avatar
92Z
5L EaTeR,
Do you remember what backspacing you had front and back? Can you post some pics of your wheels? Thanks
Old Sep 9, 2002 | 08:39 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Originally posted by 92Z
5L EaTeR,
i need to know too.
Old Sep 10, 2002 | 09:48 PM
92Z's Avatar
92Z
ttt
Old Sep 13, 2002 | 06:44 AM
Eightyninef's Avatar
would there be any interest in a 17x8.5" wheel with a 56mm offset?
I might have a set available, or just a pair??
Old Sep 13, 2002 | 06:47 AM
Grey Goose's Avatar
Car: 1990 RS
Engine: LO3 TPI
Thats a pretty high offset, what did they come off a Porsche?
Old Sep 13, 2002 | 06:51 AM
actually a C5, so they probably need spacers to fit an F-body
Old Sep 13, 2002 | 06:53 AM
Grey Goose's Avatar
Car: 1990 RS
Engine: LO3 TPI
Oh ok, thanks but I already have 18's.
Old Sep 14, 2002 | 08:50 AM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Tyre Sizes
275/40/17:
275 x .4 x 2 divide by 25.4 + 17" = 25.66" wheel
215/65/15:
215 x .65 x 2 divide by 25.4 + 15" = 26.00" wheel
Old Sep 21, 2002 | 04:28 AM
sweet82z28's Avatar
www.geocities.com/price_j_w/camaro.jpg
www.geocities.com/price_j_w/camaro3.jpg
www.geocities.com/price_j_w/camaro4.jpg
www.geocities.com/price_j_w/camaro5.jpg
82 z28 with 18's check out the pics
Old Sep 21, 2002 | 04:32 AM
sweet82z28's Avatar
I have an 82z28 with 18" wheels, currently running 245/40/18's all the way around. I was wondering what size rears I can run without making any other adjustments. Also how much would have to be done to get 305/45/18 nitto drags to fit. Any recomendations on a good tire for traction? Also from the pic doesn't it appear that I would have enough fender clearence to run wider tires. One thing I am worried about is the clearence on the inside of the tire/wheel with the inner fender but I don't care if the tires/wheels stick out past the fenders if they clear. Any help would be great. Thanks
http://www.geocities.com/price_j_w/camaro2.jpg
Old Sep 21, 2002 | 10:15 AM
Grey Goose's Avatar
Car: 1990 RS
Engine: LO3 TPI
The links don't work
Old Sep 21, 2002 | 09:05 PM
AFrikanGoodTime's Avatar
mm / 25.4 = inches
or
295 / 25.4 = 11.6
245/40-18's can be used on rim width range of 8"- 9 1/2". The recommended use is 8.5". That is straight from five different performance tire manufacturers specs. BFG, Kumho, Pirelli, Bridgestone, & Yokohama. Pirelli actually stated 8"- 10".
I'm getting close to needing new tires in the next 6 months. I am currently looking towards 18" Irocs to replace my current '87 16" Irocs. The only problem is they are only offered in an 8" width. I need to locate any machine shop that specilizes in widening rims. I will be looking to go the 8" in front but want 9 1/2" in the rear. I love my single groove Irocs and want to keep that look, only larger and wider. Anyone know of a shop in So. Cal that specializes in this?
Old Sep 24, 2002 | 12:48 AM
sweet82z28's Avatar
sorry the links didnt work....try this one......some of the info is old, but pics should come up fine.....
http://camaroz28.cardomain.com/id/sweet82z28
Old Sep 29, 2002 | 03:03 AM
89firechicken's Avatar
why does that look like some one dressed as a fire hydrent holding a sign in the backround
Old Sep 13, 2006 | 11:39 AM
1990ls1drifter's Avatar
HI can you tell me what brand rims you have on the car
I have a 1990 LS1 camaro I useing for drifting competion I need to change the rims set up. check out the web site About Us
11" rims out back is possible with some cutting, banging, and relocation. Check out WS6.COM for details on that.
Old Sep 13, 2006 | 11:54 AM
Goose Help me !
I need help I need the make and manufacturer of the rims you use on your car 1990 LS1 drift Camaro. I have been competing in drifting events for over 2 years now and the stock rims do not cut it. Need to run 255 or up to 275 X 18" front and in the rear it has to be at least 275 to 295 we will try different tire combinations.
web site About Us
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
