I took a few pics of my new (to me at least) 88 Formula today.
Old May 31, 2003 | 06:21 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Picked her up today at 1:30 and drove her 2 miles back to my house.
Here are some pics,
Needs a different exhaust, not loud enough and the tios look terrible.
You can see a little rust on the bottom of the door, no biggie though.
Needs new seat covers, those have got to go.
Will post an update in a few, going to get some knick knacks for the car.
Old May 31, 2003 | 06:28 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
what the hell is the deal with the seat covers? looks to be in pretty good shape though, how much was it? any problems ? is that the real liscense plate btw? gotta love that power bulge hood
Old May 31, 2003 | 07:11 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
not bad, but what happened to the Trans Am. I hope after all the work you didn't sell it!
You know I used to have a shirt that looked like those seat covers. Yeah, that was bad taste....
Old May 31, 2003 | 08:14 PM
Zepher's Avatar
Those plates are off of my Trans Am and are real. I just put them on the Formula so that I could drive it the 2 miles to my house.
The Trans Am is still in the garage being worked on.
Installing the 4th gen dash, new timing set, fuel lines, etc....
I paid $1700 for the car.
Only problems are the turn signal switch is broken, won't turn off the high beams, fan switch might not be working since the fans won't come on unless you jumper the aldl connector or unplug the A/C pressure switch, drivers side headlight has stripped gears in the motor, the seat covers are ugly, hatch motor needs to be bolted down since it is a little loose.
It has 105K miles on it.
305 TPI, A4, drum brakes, t-tops, rear defrost, hatch release, power locks/windows, A/C (which works, btw).
I am going to be changing all the fluids, plugs and wires, dist cap, rotor, and then use it as a daily driver till my T/A is done then maybe mod this one a bit.
Old May 31, 2003 | 08:23 PM
MdFormula350's Avatar
not bad looking.
Old May 31, 2003 | 09:22 PM
Makaveli's Avatar
looks like it has potential, not bad at all. have any major plans for it?
in this past week, you are the second board member i remember reading about, who bought a red formula for around 2000$. in this area, that sort of deal seems to be unheard of lol
good luck!
Old May 31, 2003 | 10:18 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
coudlnt you have spent that money on the trans am?
Old May 31, 2003 | 10:23 PM
Zepher's Avatar
Ya, but then I'd still not be able to drive. I am going with a 6speed, all digital gauges for the pod and the vents, and some other stuff.
So now I can do what I want to do to the Trans Am instead of doing it partially just to get it on the road.
Old May 31, 2003 | 10:49 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
Is the parking brake okay? That handle went up a little far...
Old May 31, 2003 | 11:02 PM
Zepher's Avatar
I think it might need adjustment. I've never messed with drum brakes before, they look so complicated. I'll be converting to disc soon.
What should I do to adjust the ebrake?
Old May 31, 2003 | 11:20 PM
SBlackfoot's Avatar
Engine: LB9
Axle/Gears: 2.73's
With the e-brake fully released I'd check to see if there is a lot of slack in the exposed cable under the car. They may have simply stretched over time. If so, where the front cable meets the centre cable (with one end running from one rear cable, up to the front cable, then back to the other rear cable) there should be an adjuster.
Of course, I'm only assuming that the f-body parking brake cable setup is similar to the other Chevs I've looked at. I haven't had to look at mine yet.
Old May 31, 2003 | 11:26 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Burn those seat covers as soon as possible
Overall the whole car seems in good shape and for 1700 ya cant beat that. BTW whos black 91 Z28 is that on the street?
Old Jun 1, 2003 | 12:23 AM
Zepher's Avatar
Thanks guys, I'll check the cables when I change the fluids tomorrow.
That 91 Z is actually an 86 Z with the 91 gfx and spoiler.
It belongs to a friend of mine. He bought it new in 1986.
Thing is in mint condition.
10.5:1 355 with dart heads, 58mm TB and some other mods.
Thing is pretty quick too, will take an LS1 easily.
Old Jun 1, 2003 | 12:31 AM
Car: 85 Camaro SC
Engine: V6
Awesome
I shoulda realized that, seeing how he has the 86 3rd brakelight. Thought he just swaped hatches or something.
Have you put any thoughts into painting the new bird? I think black will look killer, thou I might be biased
Old Jun 1, 2003 | 12:41 AM
Zepher's Avatar
If I paint the Formula, it will be red again. too much work involved in changing colors.
It's easy when the engine bay is empty to get most of it the color you want like I did with my Trans Am,
Car was maroon and I think you can still see some of it.
Here is my Trans Am back in February 2002,
Old Jun 1, 2003 | 01:02 AM
biff85ta's Avatar
Car: 04 Vette
You can beat that I bought an 85 ws6 car for $1000.00 just this week in about the same shape except instead of the rust on the door the is a small dentin the fender but the car has just about every option. Then again I got lucky the kid had the car sitting for four months after buying a new one and just wanted rid of it.
Old Jun 1, 2003 | 01:10 AM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
zepher can you tell me about that iroc your friend owns...
are those just 4th gen exhaust tips? could u take a better pic of them for me?
Old Jun 1, 2003 | 01:16 AM
Zepher's Avatar
Ya, those are the 4th gen z28 rectangular tips.
is that all you needed to know about the car?
Old Jun 1, 2003 | 06:55 PM
Spdfrk1990's Avatar
it was so hard to find the 92 z gfx that i got where did ur friend get his
Old Jun 1, 2003 | 11:01 PM
Zepher's Avatar
Not sure. But I can ask him.
Old Jun 1, 2003 | 11:02 PM
Spdfrk1990's Avatar
thats kewl
Old Jun 1, 2003 | 11:21 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
it's not hard at all, i just posted a wanted ad on the classified section of this site, and got 3 responses that day.
Old Jun 1, 2003 | 11:39 PM
Spdfrk1990's Avatar
when i got mine i looked all over and most places tried to sell me them with missing peices
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Dec 10, 2015 08:16 PM
Amillionoh7
Sep 11, 2015 11:36 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
