clutch engaugement adjustment with T56???
Old Jun 25, 2003 | 04:25 PM
MAMASAIDKOUOUT's Avatar
I swapped in a t56 for my old t5 a while ago and the clutch engauges/disengauges very close to the top and it is a new clutch. I want to bring down the point of engaugement to about the middle of the pedals travel, I quickly tried spacing the slave clyinder back about a 1/2" with some washers and it did not make a difference, now I am thinking i have to adjust the assembly on a part that is not the hydrolics like where it connects to the pedal or something
Just wondering if someone can save me some time if they have already gone thru this. thanks.
Old Jun 25, 2003 | 11:40 PM
pasky's Avatar
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I always thought that engaging towards the top was the sign of a new clutch?
Old Jun 26, 2003 | 09:39 PM
pasky's Avatar
I could be wrong...
Old Jun 27, 2003 | 07:58 PM
355SS's Avatar
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
Axle/Gears: 3.27 9 bolt
I cut the bracket off of the clutch pedal that the master cylinder attaches to and welded on a longer one this way I could remount the stud further away from the firewall. Now the clutch pedal is in line with the brake pedal.
Old Jun 27, 2003 | 11:50 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
what I did was just cut a 1 inch piece out of the master cylinder rod (fat part), tap both ends and made a turnbuckle out of it with something I found at the hardware store, works great and fully adjustable.
Old Jun 28, 2003 | 02:57 AM
pasky's Avatar
Pics? , These I gotta see. Was this a common problem with the T5 as well. Mine engages extremely high, however it is a new clutch.
Old Jun 28, 2003 | 10:25 AM
Tony89GTA's Avatar
Car: 89 GTA
I have no pic's but I made something on paint to give you a idea, this will work for T-5's masters also since both are pritty much the same.
Old Jun 28, 2003 | 01:05 PM
355SS's Avatar
Car: 90 Camaro
So you cut new threads on the OD and reassembled with a rod coupling nut?
Old Jun 28, 2003 | 07:56 PM
Tony89GTA's Avatar
Car: 89 GTA
I wasn't to sure what to call that thing but your right, just make sure you add two regular 3/8 nuts on both ends of the rod coupling nut to tighten it all up.
Old Nov 10, 2004 | 06:56 PM
Tony89GTA's Avatar
Car: 89 GTA
Just a update with some pic's.
Attached Thumbnails clutch engaugement adjustment with T56???-mastermod1.jpg
Old Nov 10, 2004 | 06:57 PM
Tony89GTA's Avatar
Car: 89 GTA
Attached Thumbnails clutch engaugement adjustment with T56???-mastermod2.jpg
Old Dec 29, 2004 | 03:14 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
Transmission: 95 T56
Axle/Gears: stock 10 built, yukon diff, 4.10
i have a question, instead of cutting the master cylinder rod, couldnt you just cur the slave cylinder and get the same results. personally i think its easier to get to the slave cylinder. dont have to brake my arm to get to the rod. thanks.
Old Mar 31, 2011 | 11:03 PM
supamaro383's Avatar
Car: 92 RS
Engine: 383 FIRST TPI OBDII DBW
Axle/Gears: 3.73 POSI DISK
Re: clutch engaugement adjustment with T56???
Sorry to bring up an old topic I just installed the t56 in my car with 4th gen mast,slave,pedal. I want to know what are symptoms of the mast rod being to long.for example my clutch pedal is real hi and only moves about quarter inch. after I bled the slave cylinder its real tight
Old Apr 1, 2011 | 09:57 AM
Tony89GTA's Avatar
Car: 89 GTA
Damn this is a oldie
If I'am getting this right you can't push your pedal down pass 1/4" of movement then my guess is the slave rod is not sitting on the clutch fork and is fully extended out. Careful not to push to hard or you will blow out your slave. Anyways start there and let us know.
Old Apr 1, 2011 | 10:06 AM
Tony89GTA's Avatar
Car: 89 GTA
Cutting the slave rod will do nothing to shorten the throw, it will just self adjust and fill the slave cylinder with more fluid and you have a chance at blowing out your slave if pushed to far.
Might as well correct it now just incase someone looks this up.
Old Apr 1, 2011 | 10:29 PM
Car: 92 RS
problem fixed what happen is i had my t56 rebuilt and the guy re-installed the fork pushed in, so i installed t56 with out the pulling the fork back out. long story short fork was not instelled correctly to the tob.
Old Nov 15, 2016 | 12:28 AM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
and to dig up an old thread again, im thinking about using a bearing hime joint for this project.
another thought, what about making an adj pedal stop? this would keep the pedal from going too far for those that have the fork contacting the diaphragm.
camaro1185
Oct 26, 2015 06:51 AM
topteam54
Oct 6, 2015 12:21 AM
tonys91rs
Sep 2, 2015 07:07 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
