Handling: Bigger or Smaller
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
YES... whoever tells you different is dumb. You are increasing the contact patch with the road and spreading the weight of the vehicle out a little more. There is a reason why NASCAR and indy cars have 12 to 15 wide tires. Just look at the tire sizes for new vettes and vipers. Now when it is raining this changes a little but I will get into that later.
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Car: 1989 IROC-Z
Engine: 1992 TPI 350
Transmission: 1989 T5
Axle/Gears: 1992 10 Bolt Rear w/ 3.42 gearing
wider tires reduce slip angles.....
it is possible to go to wide... if you can't get a tire into it's optimal heat range, then you are basically carrying extra mass for nothing
how wide are you thinking about going?
in autocross, it is very common to see f-bodies with 315/35 hoosiers/kumhos that are very fast
"do wider tires up front help handling?" --
YES... i guarantee you will not see any competitive ESP f-bodies running stock size tires at Nationals
if you're asking about mismatching... like 315's in front and 275's in the rear.. well, i'd have to say that's just a way to tune a car to a driver's needs...
but it's a whole lot easier and cheeper to tune a driver to a car
don't mismatch... if you want bigger.. just go with bigger all the way around..... there are many other tuning adjustments that can be made
such as:
air pressure
rebound and compression adjustments
sway bars
spring rates
such as:
air pressure
sway bars
spring rates
Car: 1989 IROC-Z
Originally posted by Gladstoneiroc
I have always wondered why? Can you give us a short physics overview of rain and wide tires?
you have your oar in hand....
the wide side of the oar offers a lot of water resistence when you stroke it through the water... so of course that's the end you're going to use to move around
now turn the oar over.... the handle of the oar offers much less water resistence when you stroke it through the water...
this relates to tires because using a wider tire is like using the big end of the oar... you get more water resistence and you can hydroplane easier
Car: '90 RS
Engine: 377 LSX
The wider your tires are the more of the vehicles weight is spread out over the contact patch. Meaning, that each squre unit of your tire is supporting a certian amount of load. The wider the tire the less load there is per unit area. Ice scaters have a really small contact patch on the ice with their skate, but that is because they are concentrating all of their weight onto a small area. This increases the contact load and actually melts the ice from friction. Now get on with tennis shoes and you slide all over the place because your weight is distributed over a larger contact area. There is not enough weight per unit ice to melt it and glide you along. Same goes for tires except you are not melting the road. The wider the tire the more water can build between the contact patch of your tire and road surface. You can support more of the vehicles weight with more water and hydroplane very easy. A narrower tire will not allow as much water between the contact patch because of its smaller contact area. Since the weight of the vehicle is now centered over a smaller area it can effectively push water away. tires do not need to be in their optimal heat range to produce grip. A tire whose compound is designed to soften and conform to the surface of the road will perform better when it is warm but that same tire will still produce grip when cold on any dry road surface. You are not just carrying mass.
True life example.
I was driving with 17x9's in my RS when I hydroplaned on an onramp going 30mph and slammed into a concrete divider.
I later that day drove in the same amount of rain the exact same spot to see what I hit and I was in a 2000 Impala that weighs more, has a higher center of gravity and whose tires are 1.5" less all around. I took the onramp 5mph faster and didn't slide one bit.
True life example.
Car: 1989 IROC-Z
tire contstruction and air pressures being equal - the area of contact patch does NOT change, only the shape of the contact patch changes
so there isn't more or less weight per unit of area in the contact patch
IT'S ALL ABOUT THE SHAPE OF THE CONTACT PATCH
Car: '90 RS
Engine: 377 LSX
Car: 1990 Camaro RS
this is a touchy subject, as rubber has some slightly diffrent properties than other matterals. i'll do a search here shortly, but i can't remeber if it was Karl Hunter, or someone else who really explained this in depth.
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
What is lacking in this conversation is tire width in relation to rim width. Fact: take a tire has a rim with range of 7-9". That tire will handle better on the 9" rim than it will on the 7" rim. Thus an 8" rim will handle better with a smaller tire than a larger tire.
Car: 91 RS Camaro
SHIFTY, I know where you are coming from there if it helps. I understand what you are saying and I agree with the area concept. I guess we just have to understand that when it rains we need to take a little more caution than normal if we upgrade our tires.
Car: '87 Chev
Engine: 60*V6
Car: '90 RS
Engine: 377 LSX
Car: 91 RS Camaro
Originally posted by AGood2.8
No, You just need to get a tire that works great in wet or dry. Hence....
Car: 1990 Camaro RS
Car: '87 Chev
Engine: 60*V6
Yes it is a Goodyear F1 GS-D3. Sell for $145 each for 245/50-16's
Heres a comparison chart to Michilen Pilot's (Sell for $253!) And Brigstone Pole pos-03's that aren't made in a 245/50 16, only a 17" rim aplication for our cars.
Note: the wet traction ratings. Dry are just slightly less- wet blows them away by 1 full sec on a hot lap.
http://www.tirerack.com/tires/tests/...d3_charts.html
Edit/ also note: That test was done on a stock Lexus IS300 with lots of body roll and camber change. These goodyears will outperform the others on dry with a flatter contact patch. The other two tires have a stiffer sidewall and will perform better on just the edge of the tire. Goodyears design is better favored sitting flat because of the slip angle vs. tread pattern. Have the right camber specs (which that stock Lexus didn't) and they will grip better.
sjorgens
Oct 1, 2015 07:54 PM
