relocating the battury to the rear glove box
Old Dec 7, 2004 | 09:19 PM
zeek's Avatar
Car: 1986 firebird trans am
is this possible? or would i have to relocate it to the spare tire's home? if i have to put it where the spare tire is is it possible to put the spare tire where the rear glove box is ?
Old Dec 7, 2004 | 11:17 PM
carbed82_Z28's Avatar
Car: 82 Z28
Engine: She's motor-less!
Transmission: th-350
I think the rear glove box is too small. Youd probably would have to take out the spare/jack, and fab up something there.
I wanna move mine there but thats were im gonna put my nitrous bottle. So ive got some thinking to do...
Old Dec 8, 2004 | 03:03 AM
The Doc's Avatar
Relocation of battery to drivers side rear storage compartment
https://www.thirdgen.org/techbb2/sho...rs+compartment
The above linked thread contains all the information and links you need. Including details of at least 3 people on the boards who have it placed there.
Just be aware that it is much easier to put in the storage well. Most people end up getting rid of the spare tire and putting it in that compartment, or using that space for other things like nitrous bottles and the like.
Old Dec 8, 2004 | 12:30 PM
zeek's Avatar
well thats what im wondering i wanna move it for weight transfer but would also like to keep my spare tire. so if i move the battury to where the spare tire is. can i move the spare tire to where the rear glove box is ?
Old Dec 8, 2004 | 01:10 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Axle/Gears: 10 bolt 3.23
I tried putting an optima in the glove box... not a good idea... I pretty much ripped all the staples off the cardboard.
As for the sides... the passenger side has more space in it than the driverside.
Old Dec 9, 2004 | 09:18 AM
biohzrd's Avatar
if you can live without the spare tire you can fit the battery there. i installed one there with a nitrous bottle in a forth gen. they are pretty close in size so it may be possable on a third gen also. don't know for sure though.
Old Dec 9, 2004 | 09:32 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Do note, that you need either a sealed box, or a bulkhead, along with a kill switch, to be track legal with the battery in the rear well.
Old Dec 9, 2004 | 04:20 PM
biohzrd's Avatar
or you could be sneaky.... go to autozone and ask them for a display battery. there is nothing in them and they only weigh about 3lbs. they also have the terminals so all you do is hook up the cables for the starter, and the ones from the battery and it is totally sleeper.
Old Dec 9, 2004 | 08:49 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
?? you mean and have this light weight one under the hood to make it look stock?
Old Dec 9, 2004 | 11:23 PM
25THRSS's Avatar
Great idea. I now know what my next project is.
Old Dec 10, 2004 | 07:45 AM
biohzrd's Avatar
exactly..... the one under the hood will look identical to a normal batt.... but only weighs in around 3lbs. tech is none the wiser all it really is is the plastic case and two terminals. just piggy back the leads. heh heh heh. totally sleeper!!!!!!!!!!!!!!!
eightsixseven
Dec 16, 2024 01:50 PM
customblackbird
Aug 15, 2021 10:16 PM
Casey Meyers
Mar 2, 2016 10:46 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
