Swaping LT1 93 ---->SECOND PART
Old Jul 22, 2001 | 12:11 AM
mat89RS's Avatar
You can get a set of headman headers for 89$ and they will work for sure.I don't think it's possible to install the engine with the headers bolted on it.(that might be your prob, I don't know) I waiting for my painless wiring now ...I'm taking a week vacation and I'll try to swap in 3-4 days..and then, tunning ...
Texas lt1, can you tell me what you used for your coolant rad hoses , thanks
89 Camaro RS Stock as a women with white panties
LT1 IS COMMING SOON.
Old Jul 22, 2001 | 06:35 AM
multi-tasking's Avatar
The problem with the hedman is that the smog pump connection on the pass side is to short. To use them would mean I would have to have someone extend that pipe. The real problem is I have spent more money than I had planned and everytime I turn around I spend more. I want some of it back This was fun until it started cutting into my beer budget!
I have heard lots of good stuff about Painless Wiring.... I have not given up on building my own harness yet - When I give up I may go with Painless.
TexasLT1, I can use some help selecting fuel lines and connectors. Thanks.
m-t
[This message has been edited by multi-tasking (edited July 22, 2001).]
Old Jul 22, 2001 | 05:27 PM
TexasLT1's Avatar
Car: '92 RS
alright guys, I got the smog-less Hedmans and bolted them up while the engine was out. for the most part, it dropped right in. the only problem was that the collector flange on the drivers side wanted to hit the lip on the backside of the crossmember where the two halves of the framing are mated. I simple took the grinder to this area and ground down just a slight amount off the ridge and it dropped right down.
matt-Im pretty sure that for the radiator hoses we just got some generic hose from NAPA and cut it too the right length
multi-if I would hav gotten on here about an hour sooner I could have asked my dad about the fuel lines and powersteering lines, he found the fittings that we used and he just left for town. I can tell you that the ps line is made up of the original tubing that makes the loop, and a fitting called a Swedge-Loc. as far as the fuel lines, the engine came with the plastic lines still attached, and they were long enough that they reached almost to the stock fuel lines. to mate them, we got this fitting that tapers down to a small point and has circular ridges around its outside. we just pushed the plastic lines on to the fitting and heated the lines with a heat gun and now you would have to cut the plastic to get them off. if that isnt enough info, my dad will be back on Tuesday and I'll ask him then
Old Jul 23, 2001 | 12:13 AM
mat89RS's Avatar
multi, just remove the emission crap thing... (if the law in your state allow it ).
how much have you spent guys, so far , including the engine..?
Old Jul 23, 2001 | 04:42 PM
TexasLT1's Avatar
Car: '92 RS
engine 1500
clutch 160
a/c components 100
fuel pump 60
all the minor crap 500+
all in all, its cost nearly 2500 to do my swap
Old Jul 23, 2001 | 05:07 PM
TexasLT1… I am in no hurry. I can wait for you to ask him. I don't want this part of the swap to be like the motor mounts…. I think MY V6 has a different cross-member than that of a V8. The nice people that I brought my engine from cut just about everything…. I have replaced a lot of stuff… If the engine has not been so clean looking I would have given it back….
Mat89RS…. I am in Louisiana. There are as far as I can tell no emission laws here… They do check to ensure that your brake lights work. The problem I have with emission is that I will be leaving this location soon and I am not sure where I am going to end-up. So, I decided to keep the emissions stuff.
Cost:……Boy Oh Boy…. In every instance when it came time to buy something I decided to buy new.
Engine and Transmission: More than it's worth
Tools: ~$100.00
Sensors and connectors: ~$200.00 -- Did not want any old sensor and if the connector looked funky I replace it also.
Motor Mounts(Attached to engine) ~$50.00 --
Motor Mounts(Attached to cross member): Cheap, but can't find receipt
Spark Plug: ~$15.00 (I can change the plugs easily, the wires are another thing!)
Spark Plug Wires: ~$75.00
Heat wrap for Spark Plug Wires: Can't find receipt
LT1 Radiator and Hoses:~$170.00
Dual Fans Setup:~$150.00
Custom made A/C Lines:~$100.00
A/C Exit Stuff:~$22.00
VATS Decoder Module:~$150.00
To be done:
Fuel and PS lines.
Deals:
Traded my V6 and tranny for some nice size 16 wheels and tires… I will keep my stock size 15 wheels and swap when the mood hits me.
Traded my R12 for A/C work. Fellow is going to ensure the system is functional, charged and does not leak. Yea, he got the best end of that deal…
Just have not decided yet:
Optispark -- Will not decide if I am going to replace it until engine is up and running.
Luckly I am an engineer and not a business person… Company would go broke with me making decisions.
Old Jul 23, 2001 | 05:13 PM
I forgot.. I changed the oil pan filter and will have the rear main seal changed after the car is running...
m-t
Old Jul 23, 2001 | 05:30 PM
mat89RS's Avatar
so far I've been pretty lucky
I traded my portable computer for 1000$ can witch I had paid 250$
bought the engine for 1700$CAD
got a tranny, 4th gen seat, all mufflers crap
bought a fuel pump, 105$CAD
traded headers and y-pipe for a BBQ (good friends makes good deals )
spark plug wire BOSCH platinium 90$CAD
sparkplugs 30$
oil and liquids of all kinds
so far, about 1000$ canadian from my pocket but I need to buy the painless wiring witch is 350$ us ...that sucks
Old Jul 23, 2001 | 05:47 PM
mat89RS's Avatar
I dropped the project when I was building the trottle cable. myself I was making one with the tbi cable pretty hard when you start cutting it. I made a little bracket from aluminium that was holding on the fuel rail bolt, and then took a bicycle brake cable and linked it with the old one (pretty crappy but it would work).I couldn't buy one because it was sunday at the time and everything was closed, custom fab was the deal .
you can simply go at gm dealer or good part store and buy a lt1 trottle cable and use it or you may even go get tpi cable , it will work fine.
Old Jul 24, 2001 | 01:43 AM
Well I think I am on the down-hill slide now. I am not going to buy a wiring harness. Its a slow and painful process but I am sure I can make the wiring thing work. 4th gen seats...Never paid attention. I do like the dash...If I thought it would fit..I would make the change...
Old Jul 24, 2001 | 11:20 AM
mat89RS's Avatar
I just got pics from my car ... here it goes
mat89RS's Avatar
Old Jul 24, 2001 | 04:41 PM
Looks very nice! The seats look like 3rd gen - are they?
Old Jul 25, 2001 | 12:59 PM
mat89RS's Avatar
seat ares from 4th gen camaro z28, I made a deal with the guy and he gave me the seats with the engine .
Old Jul 25, 2001 | 06:34 PM
I know a fellow that has a wrecked 94(?) I was looking for wiring stuff but I know the seats were in the car.. Not sure of their condition but I will check it out!
What the difference between 3rd and 4th Gen seats?
m-t
Old Jul 25, 2001 | 11:02 PM
mat89RS's Avatar
Well from my point of view and I have own 2 camaros, 87, 89, it is lot more confortable and it's more "bucket style". and it looks great in a 3rd gen
Old Jul 26, 2001 | 06:32 AM
Did you order a Vehicle Speed Sensor when you ordered your harness?
TexasLT1, did you need a VSS?
Just wondering
Old Jul 26, 2001 | 11:38 AM
mat89RS's Avatar
well multi, you don't need
VSS, only 94 and up hhave VSS , 93 are speed density ..
Old Jul 27, 2001 | 10:49 AM
TexasLT1's Avatar
Car: '92 RS
multi- sorry about taking so long, Ive been busy and havent had a chance to get on the net. I talked to my dad about the fittings, for the fuel lines we used barb fittings with a 1/4" NPT thread tubing fitting, and the power steering lines we used Swedge-Loc. we used the 95 high pressure p/s line, cut up the original p/s tubing, used hose clamps to attach the two, then used the swedge-loc to connect the two pieces of tubing. I can definately get you a pic if you need it
Old Jul 27, 2001 | 11:13 AM
mat89RS's Avatar
texaslt1, please send a pic for the fitting . thanks
Old Jul 27, 2001 | 06:14 PM
<font face="Verdana, Arial" size="2">Originally posted by mat89RS:
</font>
Where do I plug in my speedo cable into tranny?
m-t
Old Jul 27, 2001 | 06:18 PM
<font face="Verdana, Arial" size="2">Originally posted by TexasLT1:
multi- sorry about taking so long, Ive been busy and havent had a chance to get on the net. I talked to my dad about the fittings, for the fuel lines we used barb fittings with a 1/4" NPT thread tubing fitting, and the power steering lines we used Swedge-Loc. we used the 95 high pressure p/s line, cut up the original p/s tubing, used hose clamps to attach the two, then used the swedge-loc to connect the two pieces of tubing. I can definately get you a pic if you need it</font>
TexasLT1, as I am sure you are aware I do not know what I am doing... A picture would be helpful. What is a swedge-loc or who makes it... OK this may be a dumb question but what size was the fitting of the barb fitting?
m-t
Old Jul 27, 2001 | 10:01 PM
Keith5's Avatar
Car: C1500
</font>
90+ camaro's has a VSS, 87+ Firebirds have VSS.
Edit: OK I see what you mean. VSS = vehicle speed sensor. MAF = Mass Air Flow sensor. 94 and up have MAF, but he's wants to know about the VSS(in the tranny).
1989 Pontiac Firebird Formula LO3 Auto
-180 degree stat
-Hooker Cat-Back
-velcro t-top bag
-Wonder Bar from my IROC
Waiting for install: Open element 14x3, 95 vette lt1 cam
*****Possible future mods*****
4th gen seats, fiberglass spoiler, rear disc, 3.42, torsen(posi), Edlebrock Performer TBI intake, headers, y-pipe and cat, afpr
1985 IROC-Z, TPI Auto
-Accel Super Coil
engine and tranny overhauls coming this summer
http://www.geocities.com/krt80/
[This message has been edited by Keith5 (edited July 27, 2001).]
Old Jul 28, 2001 | 05:03 AM
Keith5 welcome to my world! The problem is I have a mechnical speedo and no way to connect it to my 4L60 (700R4) tranny.
The way I see it I have three choices:
1. Buy something that translates the electronic pulses to mechnical turns(?)(cost is not bad)
2. Buy a electronic speedo. (expensive and won't be happening)
3. Live without a speedo. (no cost until I do 35 in a 25.
m-t
Old Jul 28, 2001 | 11:39 AM
Keith5's Avatar
Car: C1500
<font face="Verdana, Arial" size="2">Originally posted by multi-tasking:
m-t
</font>
What year is your car? And is it a firebird or camaro?
Old Jul 28, 2001 | 12:12 PM
<font face="Verdana, Arial" size="2">Originally posted by Keith5:
What year is your car? And is it a firebird or camaro?</font>
1989 Camaro RS with a V6(2.8L MPFI). Thanks in advance for your help.
Ron
Old Jul 28, 2001 | 03:40 PM
UnderDogRS's Avatar
Street & performance makes a tailend housing kit that lets you add a manual speedO to a 4l60e. maybe it would work on a 4l60 or maybe they make a kit for your app.
HTH
RS
<A HREF="http://ca.geocities.com/zander0710/" TARGET=_blank>
1992 Camaro RS</A>
****In The Work****
94' Z28 Drivetrain(LT1,4L60E,PCM,3.42 posi w/ disk), Walbro 255P fuel pump
!A/C,!cat, !A.I.R, Full Hooker exhaust,Custom program(Rev.b based)
Old Jul 28, 2001 | 10:49 PM
Keith5's Avatar
Car: C1500
<font face="Verdana, Arial" size="2">Originally posted by UnderDogRS:
HTH
RS
</font>
You should be able to just swap out a cable driven setup into the 4L60 not sure about the 4L60E.
I don't know what you should do about the speedo. Camaros were supposed to get electic speedos in '90, did the dash change in 90 or 91? Maybe you could use stock electric speedo or something.
I would say just take out the VSS and use the cable setup, but I'm not sure what the LT1 computer would think about that. You'd have to do something about the converter lockup and it might throw a code or something.
Old Jul 29, 2001 | 12:52 AM
mat89RS's Avatar
Multi, do this , it works:
remove the 4 bolt on ther tail of the hold and also the new one
exchange the tail, but change the plastic gear because it's not the same, and it will work just fine .
By the way, I'm currently swapping guys, so far it's good, I've removed the engine and I'll be installing the engine tomorow. it took me 6 hours so far .
Old Jul 29, 2001 | 12:55 AM
mat89RS's Avatar
sorry for spelling mistake, I drank to much beer !
Old Jul 29, 2001 | 07:40 AM
Thanks UnderDogRS and Keith5! I think the first thing I will investigate is the 90-92 model Camaro. I would like to use electronic speedo and if one of those model years had one and it will fit I will.
The VSS from JTR or painless will be my second option.
Option three will be to put a kit on the tranny.
I would say just take out the VSS and use the cable setup, but I'm not sure what the LT1 computer would think about that. You'd have to do something about the converter lockup and it might throw a code or something.</font>
I think the computer will receive its signal… It is wired directly into the tranny. The tranny section of the Helms is very complicated (at least it makes my head hurt).
m-t
Old Jul 29, 2001 | 07:42 AM
</font>
I traded my v6 and tranny for a set of rims...
m-t
Old Jul 29, 2001 | 09:45 AM
Well I guess this swap is taking longer than I had planned. Some of my labels have fallen off. What is the black, round (1-2 inch in dia), about 5-6 inches long with the brown wire running to it. It is on the driver side near the tranny. It has a opening and looks like something plugs in like a cable or something.
thanks
m-t
Old Jul 29, 2001 | 05:58 PM
mat89LT1 at least tell us how it went! Did it work out? Did you write down what you did? Got any te(a)ch article material?
v/r
m-t
Old Jul 30, 2001 | 01:49 AM
mat89RS's Avatar
Well so far it's going great, tommorow I'll be changing the fuel pump and dropping the rear-end , and I'll be starting the electronic. I had two small problems today, I was trying the drop the engine and the right side header was not fitting , I had to remove it, now the other problem is that the left side header is touching the heather core return line.I'll relocate it. hing else is working fine
multi too bad you exchanged that tranny , would ove been really helpfull
Old Jul 30, 2001 | 06:49 AM
</font>
Huh?
Old Jul 30, 2001 | 08:57 AM
Keith5's Avatar
Car: C1500
m-t
</font>
Old Jul 30, 2001 | 12:12 PM
UnderDogRS's Avatar
has anybody used the 3rdgen radiator.
i remember seeing it done, but cant seem to find it.
Thanks,
RS
Old Jul 30, 2001 | 12:43 PM
mat89RS's Avatar
I've used 3rd gen rad, I used the waterneck from the 305 and I've found a rad hose from a g-body that fit perfectly, everything else works just fine.
I'll try to get pictures for things that are hard to figure out .
Also my power sterring line are made now with the old flex and 2 fittings that I bought at Canadian Tire. the power sterring line passes under the actual engine.
I'm in the process of building my fuel feed and return lines. I want to make something nice so I'll buy more fittings and metal lines (just the same as power sterring).
I didn't find an air intake that works with the engine . I'll probably use one from a 2.8 camaro. (it's been sitting in my garage from 2 years, why not use it)
Old Jul 30, 2001 | 12:47 PM
mat89RS's Avatar
I'm thinking about buying 3.73 gears and posi unit because I'll drop the rear-end tonight or tommorow and it's lot easier to do it while it's not on the car . not sure ... will see.
Old Jul 30, 2001 | 12:54 PM
Electromaro's Avatar
i have a question. is there anyway to archive these two 93 swap posts into like a tech file or something or have like a greatests hits list
Old Jul 30, 2001 | 04:50 PM
Keith5, who do you think got the better deal?
m-t
Old Jul 30, 2001 | 04:54 PM
<font face="Verdana, Arial" size="2">Originally posted by Electromaro:
i have a question. is there anyway to archive these two 93 swap posts into like a tech file or something or have like a greatests hits list</font>
The plan is to come up with technical articles that we can post on this site. As far as archiving I think(hope) that automatic. I am also saving it to my hard drive.
m-t
Old Jul 30, 2001 | 05:18 PM
mat89RS's Avatar
I will come up with pictures and as soon as I finish that swap. I'll have time to build a page with ALL the info and I'll work this out with multi for electronic, texaslt1 for ideas and cool tips and tricks, eric for archives, and badas.bid for contact and larry1992lt1 for burnout pictures ...i'm kidding guys !!!!mouhahaha. We will figure out something together. We should chat on mIRC one day and discusss that .
Old Jul 30, 2001 | 05:52 PM
I've used 3rd gen rad, I used the waterneck from the 305 and I've found a rad hose from a g-body that fit perfectly, everything else works just fine. </font>
I am using a 4rd Gen radiator. Not sure if its going to work or not. Have not put it in yet! With my luck it won't!
I'll try to get pictures for things that are hard to figure out . </font>
Yea lots and lots of pictures!
Also my power sterring line are made now with the old flex and 2 fittings that I bought at Canadian Tire. the power sterring line passes under the actual engine. </font>
Where? Got pictures?
I'm in the process of building my fuel feed and return lines. I want to make something nice so I'll buy more fittings and metal lines (just the same as power sterring). </font>
Which metal lines are you using?
</font>
This site says that will work great! And he has pictures! www.lt1powered85z.cz28.com/custom.html
v/r
m-t
Old Jul 30, 2001 | 09:05 PM
</font>
However we do it we need to write in-depth tech pages....I have spent more time searching for information than I have working on my car. I know that as a collective we can turn out some good stuff that will benefit folks like us that love our cars. I think posting on this site is a great solution and maybe cross-post elsewhere...As a collective we can lighten the next person that want to do this load.
Mat89RS is correct., we need a plan of how we are going to approach this and what our end product will be... That chat program maybe a way to get us started...
I think Mat89RS should do electronic!
m-t
Old Jul 30, 2001 | 09:14 PM
Huh?
</font>
Hi I posted a question in Electronic concerning --of course--an Electronic Speedo in a thirdgen... 90+ cars have electronic speedo... We should be able to swap our mech ones for electronic ones...
m-t
Old Jul 30, 2001 | 09:46 PM
Keith5's Avatar
Car: C1500
m-t
</font>
I don't know depends on the wheels, but since you don't need a v6 tranny I'd say you did.
On the speedo thing. I'm not sure a 90+ speedo will work in an older car's dash without mods. I know 91-92 dashes are different, 90's may not be. I guess after putting an LT1 in a 3rd gen, making a speedo fit would be trivial.
Old Aug 1, 2001 | 06:24 PM
Keith5 you are 100% correct on speedo. I am going to stick with mech.
v/r
m-t
Old Aug 1, 2001 | 09:43 PM
Keith5's Avatar
Car: C1500
v/r
m-t
</font>
How right was I? Will it cause you to loose your lockup and throw a code? I guess you can put the lockup on a manual switch or use one of those vacuum operated switches out of jegs or something for lockup. Maybe the computer can be reprogrammed to not care about the VSS.
