LT1 or L98
Old Oct 12, 2001 | 12:51 PM
86transammike's Avatar
LT1 or L98
Alright, I'm sure you guys get these questions every single day, sorry. I have an 86 T/A 305 TPI, Auto Tranny. What do you think would be the better choice, I'm either gonna drop an L98 in it, or an LT1, the money diff is about $500. LT1 obviously being more expensive. I was going to try and keep my TPI and put it on either engine...I just wanted to know if that would be difficult to do?? or not?? Thanks, Michael, just gimme on a scale of 1-10 on difficulty
Old Oct 12, 2001 | 12:53 PM
Tas's Avatar
Tas
don't choke the LT1 with your intake. Leave the LT1 intake on it.
p.s. sell the TPI to me TPI is perfect for 305s but they choke 350s without upgrades. upgrades = $$$$
Old Oct 12, 2001 | 01:00 PM
well see, its a long block, no intake on it....i work at Discount Auto Parts, the guy i got this idea from, he has an LT1 and the TPI on top of it, he said it runs great, but I'm not sure, so it chokes it??
Old Oct 12, 2001 | 05:34 PM
mat89RS's Avatar
It wouldn't be a good thing to put the TPI on the lt1. LT1 is working with optispark... you wont be able to put you intake on the lt1 because it has no water passage in the intake and you'll have issues with the TPI distributor. also TPI intake is not even a good intake to put on a mild 350...miniram is much better and it will let your engine breath lot more.
If I were you I would do like I did, install the complete lt1 setup in your car, do the wiring harness yourself, I can give you info on about anything. my total swap costed me about 2500$ Canadian.
LT1 POWERED
HEADMANS HEADERS
300 HP backed with a limited slip, 2.73.
Top speed reached: 150 mph
EATS MUSTANGS FOR BREAKFAST
Old Oct 12, 2001 | 09:29 PM
Tas's Avatar
Tas
<font face="Verdana, Arial" size="2">It wouldn't be a good thing to put the TPI on the lt1. LT1 is working with optispark... you wont be able to put you intake on the lt1 because it has no water passage in the intake and you'll have issues with the TPI distributor. </font>
um no. You can put the TPI on the LT1 easily as long as you redrill the intake holes to match the LT1 heads. You can use your old distributor. You don't need to use the crappy optispark. You block off the TPI thermostat opening because there will be not no coolant flowing through it.
<font face="Verdana, Arial" size="2">also TPI intake is not even a good intake to put on a mild 350...miniram is much better and it will let your engine breath lot more.</font>
correct
I've seen LT1 intakes with fuel rails for $110 at www.camaroz28.com maybe you can run it off your TPI electronics
-Tas
'89 Formula WS.6
Mods and times:
TOP SECRET
Got Beach?
[This message has been edited by Tas (edited October 12, 2001).]
Old Oct 13, 2001 | 03:54 PM
mat89RS's Avatar
Tas, I do believe myself that optispark is a very good system ... gas mileage on lt1 is pretty good because of that and it's fuel injection system. lot of people complain about it. if you check you water pump once every 60000 miles you will be alright. Even do my water pump did leak on mine it didn't blew it and well my solution to this was to put and actual sheet of metal between the WP and OPtispark.
I strongly believe also that if GM did this system in camaros, corvettes, impalas and Roadmaster it show that it as been tested alot and it was the right thing for these engine even do a regular distributor would have been working without major problems.
LT1 POWERED
HEADMANS HEADERS
Old May 31, 2011 | 11:44 PM
THE PIRATE's Avatar
Car: 1986 TRANS AM
Re: LT1 or L98
Please coach me through that.... will a lt1 off a 95 trans am fit a 86 TA??
Old Jun 1, 2011 | 12:12 AM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Re: LT1 or L98
not without lots of work. Drilling the intake for the right bolt pattern, drilling the intake for a distributor hole, welding aluminum to the manifold to machine a pad for the dist, drilling the intake for water crossover pipes...
Old Jun 1, 2011 | 12:43 AM
THE PIRATE's Avatar
Car: 1986 TRANS AM
Re: LT1 or L98
ok... which do suggest??? im on a budget and not a seasoned wrench turner....
Old Jun 1, 2011 | 01:42 AM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Re: LT1 or L98
go just plain lt1. ive seen full drop outs with harness , pcm, and trans{ auto} for under 1000. bolts in physically but a bit of wiring and fuel line plumbing is needed. wiring is explained very well in the ltx forum.
91chevyz28
Feb 10, 2022 07:58 PM
FormulasOnly
Jul 23, 2018 08:47 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
