Tesing of new code.
Old Mar 17, 2002 | 12:03 AM
32V_DOHC's Avatar
Tesing of new code.
Hello all
I have written a few lines of code into the aujp prom to allow for datalogging of the wideband o2 using Craigs software. It runs on the simulator but this does not mean it will run in the 7730. I need help testing it. The WB signal will be input on pin A3 and will be seen as the canister purge signal. The standard 0 - 255 = 0-5V applies. I have attached the bin if anyone wants to look at it or try it out.
Thanks in advance for tips or tricks
John
File Type: zip
Old Jul 12, 2002 | 10:26 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Axle/Gears: 3.23 Dana 44
What ever happened to this? Are people still working on this? I am saving up for a WB O2. I am very interested in this idea of adding the WB O2 to the ALDL data stream.
Old Jul 13, 2002 | 07:53 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Holy Crap. I don't know how I missed this post before. AWESOME. Now if I can just get my car finished!
Tim
Old Jul 13, 2002 | 12:03 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Tim
Yea this was posted back in march and somehow it got missed altogether. Once I get $140 for my WB O2 I am definitely going to put some time into making this work.
Old Jul 13, 2002 | 04:47 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Would it be possible to use one of the other pins that the SD V6s use but are FREE on the SD V8s? Like D13 which is the input for the Power Steering switch that only exists on the $88 V6 calibration. The actual "driver" for D13 exists in ALL 7730 ECMs. This would allow ALL SD users, including those retaining all their emission equipment to take advantage of this change.
Alternatively, there is D12, the "High Pressure A/C Switch" for Fan 2. In the AUJP code, this switch is ONLY informational, the calibration doesn't really do much with it as the 7730 cannot turn on Fan2. I've "manually" set it on and found no differences in the operation of my engine except for my scan tool reporting "FAN 2 Request On" (even though Fan 2 still was not on). I did a lot of testing on Fan 2 and basically the input does nothing other than "reporting" from what I've can see.
Lastly, how about some "outputs"? I have found an output F5 from the V6 that is for a "Third EGR Solenoid Control" that is not used on the SD V8 calibration. I am thinking that this would be a dandy one to use to FINALLY make the ECM actually control Fan 2 via the CTS or other criteria like A/C, Temp and VSS....like I truly believe the ECM was intended to have, but go "nixed" by someone in GM. I guess someone at GM didn't want too much "reliance" on these "new fangled computers and wanted a "hardware solution" incase the ECM/software didn't function properly.
Old Jul 14, 2002 | 04:21 AM
funstick's Avatar
no man the fan thing was al QC. they f'd up. if you have an open
swtich on yr ecm can adress it direct the ecm to turn it on. you have the code you have the know how.
Old Jul 14, 2002 | 11:54 AM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
I guess from a bean counters point of view its cheaper to warrenty the ECM than replace a cooked motor..
funstick, your replies make my brain hurt.
Old Jul 14, 2002 | 12:08 PM
32V_DOHC's Avatar
Thank You
Glenn
I think you misunderstand what I did. I have taken the input on pin A3 (an unused a/d port) and used that to get the voltage into the computer. I did not disable the CCP I only used the byte reserved for it in the ALDL stream. Emmision comliance is fully retained.
I am currently working on version 2.0. It will look up A/F ratio from a table and output it to the Batt voltage Byte so that A/F ratios will be displayed correctly. The No CCP data was never a problem because I always turned it off to tune.
HTH
John
Old Jul 20, 2002 | 07:47 AM
Z28406T56CONV's Avatar
First, I think this is really useful, what you've done! Thanks for sharing!
I noted that you have a 25.x lb/hr injector constant, and that you have VATS disabled, when compared to AUJP1615. Let us know if I am mistaken, but the testers might want to note this (If they're like me, they investigated first
Third, a question...AFAIK, the good ol 1-wire GM o2 sensor chemically produces about a 0 - 1v signal based on the lack of o2 running down the pipe... On your test bench, are you using a directly connected WB, a GM o2, a "DIY_WB board"'s output? or just a pot(wiper from a TPS?)
After I look at what you have at $2000 for a bit (looks like might be chip channel select and sensor read?), I'll test it out with a spare TPS and let you know if my aldl package sees it... I assume you've written it to the datastream, therefore any package that grabs the canister P% will see it, not only Moates. I may be a while before I get back with the results, but I will.
Lastly... something neet to think about doing.. spare OUTPUT! yuummm... :-))
thanks again!
Old Jul 21, 2002 | 01:44 PM
32V_DOHC's Avatar
You are correct. I would hope that everyone would look at whats on a bin before just burning it and trying it. This was kind of meant as a key on but engine not running test.
I plugged in values to a hc11 simulator. Later I used a wiper for testing as the WBO2 output can not easily be varied though the whole range.
That is exactly what I did. The WB output is 0-5VDC the same as TPS or MAP. Using a spare channel meant that all that was necessary was to read the channel. Then I stored the value in a spare RAM location and changed the CCP ALDL byte to read that RAM location.
Good luck with it
John
Old Jul 21, 2002 | 05:33 PM
" That is exactly what I did. The WB output is 0-5VDC the same as TPS or MAP. Using a spare channel ......."
To be clear, are you saying the WB itself is 0-5v, or the COMPLETE DIY_WB setup is 0-5v?
thanks.
Old Jul 22, 2002 | 07:12 AM
32V_DOHC's Avatar
The COMPLETE DIY_WB setup is 0-5v.
John
Old Oct 27, 2002 | 03:16 PM
JPrevost's Avatar
Car: 91 Red Sled
TTT, any new news?
Old Dec 10, 2002 | 11:04 AM
TRAXION's Avatar
Hey John,
Just following up - did you ever get 'version 2' completed?
Tim
Old Jan 4, 2003 | 04:40 PM
I started poking at the code patch you made, and after I documented what you did I have a couple questions... (I still have not tried it on the car, I have to port it over to my application exactly)
Q1: I see nothing done to the datastream in the chip. What VIN are you using with the software (moates, I'm not familiar with its operation sorry but I have been wanting to get set up with it ) to get location $0034 to spit out? It does not look (codewise) that it will ever spit out of the datastream but again, I have not put it on the car. I plan on changing some things beyond what you have done so if you tested on a hc11 simulator and looked at the ram location directly and saw it working... I still need to take it foreward to the datastrteam.
(edit: - OK, I re-read more.... if $0034 is already in the datastream then that's why there are no changes there. "Canister purge" huh... ok!.. but isn't that written-to in the code already?) - I'll shut up now.. this post is almost moot except that I say I'm working on it! )
Q2: I can go look this up, but what PIN is channel 0 on?
(duuh-- A3 - I re-read the thread.. nevermind) :/
PS, whats version 2? Did you address any of the above? I don't see a reference to version 2 in this thread.... ?
{edit: (smack) I see that now too.. I think the WB is *nearly* linear... might be close but never perfect}
Thanks again and I hope to have results for you at some point.
Old Apr 17, 2003 | 10:02 AM
Craig Moates's Avatar
Car: 87 T/A
Did someone get the WB02 logging to work with a 165 / 6E hack? I missed it I guess...
...but would be interested...
Old Apr 17, 2003 | 10:21 AM
funstick's Avatar
craig do you have the $6e hack handy ?im having a hardtime retreving mine from the laptop. if so toss me and email.
Old Apr 17, 2003 | 01:19 PM
TRAXION's Avatar
https://www.thirdgen.org/techbb2/sho...hreadid=105227
Old Apr 30, 2003 | 10:13 AM
LBSZ28BLOWN's Avatar
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
Question,
is the checksum disabled on the 8dwbo2.bin.
I was making some changes to the TCC at 0x610F and was wondering if the checksum needs to be recalculated.
TunerCat's CS utility dosen't seem to work with this 8dwb02.bin or mabey its been disabled.
Old Apr 30, 2003 | 10:57 AM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Is the Program ID set to AA?
Old Apr 30, 2003 | 11:48 AM
If the prom ID is located here it looks like its set to 8A.
0000: 8A C6 L0000 ORAA #$00C6 ;..
L0001
0002: FF FF FF STX LFFFF ;...
When I run the TunerCat CS program with the WBO2 bin
nothing shows up at all on the screen, works fine with my .bin files
Old May 3, 2003 | 02:47 PM
32V_DOHC,
I just finished Installing and hooking up my DIY WB and transfered all my settings to your 8dwbo2 bin and my Vout to A3.
It works just as avertised, really cool stuff its going to make data loging and tuning a breeze.
thanks for all the info.
Any more work being done on ver. 2
Old May 4, 2003 | 03:27 PM
This is great stuff.
Ok have it all hooked up and running, I show a CCP vout value of 51 and the WB02 A/F meter is showing 14.6 to 14.7 at Idle I show a CCP vout value of 48 and the A/F meter shows 13.8.
How do I calculate the A/F ratio.
is this how it works
CCP values 0-255 = 0-5v
So that being that 255/5 = 51
CCP vout value 1 = .0490196 vlts
so I just Multiply the CCP value by .0490196 and that = the Vout and that converts to AFR using the chart.
if thats so.
Then a CCP value of 40 X .0490196 = AFR of 11.96.
Dose this sound correct.
Old May 30, 2003 | 07:33 PM
87IROC350's Avatar
Engine: 5.7
BTTT... This is great stuff any new updates? I'm just finishing my WB02 assembly and will be looking to use this shortly.
Old May 30, 2003 | 07:46 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Mike has hacked the following calibration using 32V_DOHC info:
$8D - AUJP ('92 TPI 350 w/A4)
$8D - AXXC ('92 TPI 305 w/M5)
$6E - ARAP ('89 TPI 350 w/A4)
$6E - APYP ('89 TPI 350 {vette} w/M6)
You can download the bin’s here:
http://www.eecis.udel.edu/~davis/z28/WB_hacs/
Old Sep 17, 2003 | 07:34 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Wow!
If anyone has any info on how I could attempt this for a ....
$32B - ABTB ('87 TPI 350 Vette w/Manual Tranny)
....I would be forever grateful!
Old Sep 17, 2003 | 10:23 PM
Swapmaster's Avatar
If you were using DataMaster-8D would the reading show up as the CCP-DC?
Old Sep 17, 2003 | 11:05 PM
Car: 87 T/A
I've got it working with a few mods to the 6E code. Just bring it into MAP2 and route it to MAT2 on the ALDL stream. Or I guess you could just send it as requested AFR same as the 730 deal...
Old Oct 22, 2003 | 08:49 AM
Badas.sbird's Avatar
Car: 1988 GTA
Engine: 404ci LS2
Transmission: 700R4 Full Manual Reverse
Axle/Gears: 3.91 Australian 9 Bolt
Hey guys. I am code stupid but a longtime programmer. What all do I need to do this and can someone explain what this is actually going to do and how I will receive the WB data?
Tracey
Old Nov 15, 2003 | 10:23 PM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
TTT Anything new here?
Old Nov 17, 2003 | 12:51 AM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
Nothing new as far as I know, however I would like to use this code for the Innovative Motorsports WBO2 that I just bought. From what I hear the voltage/AFR relationship is different for the DIY and this sensor so the table in the code needs to be changed.
I haven't done anything with this yet but plan on it. I guess the first step is compairing the code between this .bin and the stock AUJP to see how they put this additional table in there. Or if someone has an ECU that has that table it would make my life easier...????
Never played with code before.
Old Oct 4, 2004 | 12:59 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Hac for AXXC WB
I tried it and it worked great, it read out on the Datamaster air-fuel value box. I use it with the LM-1 WB. Only now I have a problem, the next time I hooked it up I can't link from the ALDL connector with anything I try (Datamaster, Diacom, OTC) I have tried different PROM's and everything, adding the WB hac and removing and reinstalling ...nothing works anymore. Until I put back the regular PROM (29c256) I have been using, then everything is fine (but with no WB).
Old Jul 20, 2006 | 07:34 AM
fury pilot's Avatar
Engine: GM 2.0XE
Just to confirm, the output of a WB02 system is being wired to an ECM pin, not just a wide band lambda probe?
Old Jul 20, 2006 | 11:20 AM
JP86SS's Avatar
Yes, you want the voltage output of the controller.You can not operate the sensor from the ECM.
dusterbd
Sep 29, 2015 08:40 AM
1Aauto
Sponsored Vendors
Aug 31, 2015 09:46 AM
mrestrictrplate
Aug 27, 2015 09:37 AM
RS91
Aug 19, 2001 01:28 PM
