interesting code change,is it possible?
Old May 6, 2002 | 01:06 PM
kvu's Avatar
kvu
One of my crazy ideas is a wide band o2 sensor translated to the ecm ,then emplement in the code a readout of a/f ratio in the diagnostic data stream that coud be read from a scan tool.That would make tuning a snap.I am trying to learn how to read the bin without tc.I have done some changes by modding the bin manually. Someday this would be nice to add to the code.
Old May 6, 2002 | 01:22 PM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
Anything is possible as long as you know how to manipulate the code. All you have to do is look for an open input in the ecm (which it has various ones open) and feed the WBO2 there. Then write code for it to be seen by the ecm and sent to the scan tool in the diagnostic output serial data. Actually, I believe someone has already done this and replaced his narrow band O2 input with that of the WBO2 and then runs the thing in open loop and tunes by the WB output on his scanner. Sounds simple enough if you know the inner workings of the ecm's code but impossible if you don't. Not to mention the fact that it's not just add code but intertwine it to the existing code which then means that the editor you have for making nice quick changes to your tuning will probably be no good and you'll have to make anew definition file to make up for it. Simple right?
Old May 6, 2002 | 05:07 PM
AlexJH's Avatar
Engine: 5.7L V8
The ECM already outputs the O2 sensor voltage (at least on mine, 165) , so why not just have a spreadsheet that does the conversion?
Old May 6, 2002 | 06:20 PM
Jza's Avatar
Jza
Because:
A) The ECM is outputting the stock narrow-band sensor voltage and it's not accurate for WOT tuning
B) A spreadsheet conversion is useless because of that inaccuracy.
C) That still has nothing to do with altering the ECM source code.
Old May 6, 2002 | 07:27 PM
AlexJH's Avatar
Engine: 5.7L V8
Oh, I always assumed that a WB O2 sensor's output was the same voltage at 14.7:1 as the narrow band one. So you'd just use the (correct) WB readings instead.
Easier than altering source code IMO.
Old May 6, 2002 | 08:50 PM
Craig Moates's Avatar
Car: 87 T/A
I'd second the thought of mapping a WBO2 signal into a pre-existing input that is already carried to the ALDL stream. For instance, the MAT sensor of a 165 unit. If you could get the signal from the WBO2 in the right range, it should be pretty straightforward to bring the data from the WBO2 to the ECM to whatever datalogging system you have. Then just do the calcs post-facto.
Heck, if someone cares to demonstrate this or a similar approach, I'd be MORE than happy to add the calc to my ALDL program. Then you could have a nice field which gives WBO2 voltage and the related AFRatio. If you want, I could even make up a little bar-meter which shows rich-lean condition along with the AFR value as it moves around. Might even make it red & green like those little ***** deals.
Deal? Somebody do it, give me the specs, and I'll do the ALDL end of it. If you're deadset on modifying the code, give me a holler about what input you want to use and maybe we can figure something out.
Old May 7, 2002 | 10:02 AM
32V_DOHC's Avatar
Been done already so yes it is possible.
1. The DIY-WB output is already 0-5 vdc so no hardware is needed, but you cannot input it on the o2 sensor pin. The place I chose for the input was tps2. I found the correct pin at Ludis' site.
2. Adding code is as simple as finding a spot to put it and a spare ram value. You intercept the code right after the NB O2 sensor read and goto your code for a wide band read. Once you have read the value then you can do an index lookup table for an actual A/F ratio. Then you place this on the ram value you have chosen..
3. Then you can take the ram value in the data stream that represents battery voltage and substitute the new ram value. Craig Moates software says its battery voltage but what I am reading is A/F ratio.
This is where source code would help a lot. I do not have source code but to do this I disassembled the bin and made changes and then reassembled the bin.
Anyone who wants to try this let me know and I will help to walk you through it.
John
Old May 7, 2002 | 12:58 PM
kvu's Avatar
kvu
Could you walk me through it in detail?You used the battery voltage for af ratio.How does it work.Is 12.2 volts 12.2 a/f ratio or what?
Old May 7, 2002 | 02:13 PM
32V_DOHC's Avatar
Battery voltage output is a/d count divided by 10. So you choose table values that are A/F times 10 so that 12.2 volts on the scan tool equals 12.2 a/f
Do you have a disassembler and an assembler? Have you disassembled your bin and then reassembled it and gotten the same file? Which ECM are you working on? Have you been to Ludis' site and looked at the schematics?
I will be glad to answer all questions about this. I do have limited time so please excuse my short answers.
John
Old May 13, 2002 | 11:45 AM
kvu's Avatar
kvu
I have not dis and reassemble my bin,yet.I can get a disassembler from tc right?I am a quick learner and if you show me how then I can do it.I am working with the 6e.
Old May 14, 2002 | 08:00 AM
32V_DOHC's Avatar
Tunercat's disassembler will work. You also need the motorola assembler. You should disassemble then reassemble, convert to a bin file and then check to see that the new bin is the same as the old. Once you are sure that the disassembly that you made is good then you need to pick an input pin. Let me know when you have done the dis/re assembly and I will help you pick a pin.
John
Old May 14, 2002 | 11:01 AM
kvu's Avatar
kvu
Ok from what I understand,I need to disassemble and reasemble the bin to gain access in to modify things,right?I can read up on how to do this.Then find the pin to run the w/b to.But the next part I might have a bit harder time doing.I have read the bua hak and can make some sense of it all.But you stated I will need to code the w/b into the bin.I have never coded anything and don't want to get to a point where I am wasting your time.But if your willing to help I can do it.
Old May 14, 2002 | 01:15 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
kvu, if you are using the same mask as the BUA it might be
easy. On the diy_efi incoming site there is a copy of the BUA
hac that is assemble-able already. Something like bua.txt.
The name may by different and might have a different case
(case sensitive server).
Then just replace the calibration info with the stuff from your
bin and re-assemble. Done. Plus it is already commented.
RBob.
Old May 15, 2002 | 04:24 PM
32V_DOHC's Avatar
I have always been thankful for people who were willing to help when I wanted to learn. If you wish to learn you will not be wasting my time. The programming involved in not difficult. Maybe 10 lines or so. To use the 6E you will also need to go to a larger PROM(256) or cull the program to allow space for the extra code.
John
Old May 16, 2002 | 10:14 AM
kvu's Avatar
kvu
I have disassembled the bin.But I need to get the motorola asse mbler.After I converted the src back to bin I will get back to you.Thanks for taking me under your wing here.
Old May 19, 2002 | 12:20 PM
kvu's Avatar
kvu
Can you give me a link to the motorola assembler?What about rbob's comment about the bua ready to reassemble?
Old May 20, 2002 | 11:22 AM
kvu's Avatar
kvu
I found the assembler but need some help how to use it to assemble my .src.32v-dohc can we swicth this to email,this thread is getting burried.
Old May 20, 2002 | 01:00 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
This thread happens to be worth devoting the space to IMO.
I'd sure like to be able to see what'll you guys are up to....
Old May 20, 2002 | 05:49 PM
32V_DOHC's Avatar
I agree.
Maybe we can convince one of the moderators to make it sticky.
The bua is 32b mask. If you want to do this to the 32 then we can do that also.
If you want you can email me your file and I will take a quick look at it.
John
Old May 20, 2002 | 06:01 PM
32V_DOHC's Avatar
I think while you are getting the assembler stuff taken care of we should look at the choices for pins. The wb has an output of 0-5 VDC and this is what most of the sensor inputs for the computer are. I have cropped some images from Ludis's site (I hope he does not mind) in order to show what I mean. The 165 has two unused Map ports that may be used for signal input.
Old May 20, 2002 | 06:02 PM
32V_DOHC's Avatar
These are taken from the pins c11 and d8 respectively. We will use one of these.
John
Old May 20, 2002 | 06:13 PM
32V_DOHC's Avatar
This is the a/d chip in the 165. It shows map2 on channel 0 and map on channel 3. We will use this information to write the software for the input. We need only hook the output of the wb to pin c11 or d8 and make the appropriate changes to the code to allow us to store, manipulate, and log wb data through a scan tool.
John
Old May 20, 2002 | 06:34 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Hope you don't mind if I tag along. This sounds very interesting (something I'd try). But I am running a '749 with $58 mask on a TPI. Looking at Lugis site I see several inputs that maybe usable, I am looking at the unused MAF input (F10). Any suggestions? I have the HAC you posted a while back for the $58 and have a .pdf titled Functional Features of the PFI 2.0 Turbo, really breaks down whats what. Like kvu I do not have much programming skills, but will put the time in to sort it out. thanks, Bob
Old May 20, 2002 | 08:55 PM
kvu's Avatar
kvu
I have sent you my bin disassembled.I'm using the 6E mask.I was looking at the bua to see generally where my tables are.I don't know the starting address so I'm not sure if it's disassembled right.I still need to learn how to assemble my source file.Glenn or Traxx should make this sticky,I agree.It just seems like the final missing link in the w/b project.I guess whatever pin (c11 d8)will be better,if it matters.Thanks again for your generous help 32V_DOHC.I have made straight fs from 6 grade up to 10th,then I quit school.But I am picking this up,so far.
Old May 22, 2002 | 06:14 PM
32V_DOHC's Avatar
I would stay away from pins that are not ground seeking. The way the MAF pin appears to work is that the difference between 5v and sensor voltage is taken on the resistor. This means current flows to the sensor. This may or may not be a problem. The sensor voltage is also inverted. This is something you would need to account for.
I think that the TPS2 or MAP2 pins would be more appropriate. This is the way I did it for the 8d code
HTH
John
Old May 22, 2002 | 07:28 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Thanks John, I'll go with your suggestion and use the MAP2 pin. Presently dis/*** my bin, and comparing it to yours to see if I did it correctly. Other than changing the Knumcyl to $00 (8) and changing the injector size to reflect my injectors I have not made any further changes to my bin, ABYN base. cheers, Bob
Old May 23, 2002 | 11:21 PM
kvu's Avatar
kvu
Hi 32V_DOHC,I got your email.I understand and can do all of that.But before I disassemble my bin I have a few more questions.Will the file start address and the disassembly start address be the same($c000)?Should the start address use # before $c000.Do I need to fill the dis start and end address or use default?What about the comment character and label symbol,leave it alone?Should I include hex values,ASCll or just the hex address.After these questions I should have a dis/reassembled bin,ready to go.
Old May 29, 2002 | 02:07 PM
kvu's Avatar
kvu
32v_dohc,have'nt heard from you I hope everything is ok.
Old May 31, 2002 | 08:25 AM
32V_DOHC's Avatar
I am fine. I have been really busy with work and the holiday. I have not had much time for the net.
John
Old Jul 4, 2002 | 01:39 PM
kvu's Avatar
kvu
Due to the cost of a maf I will be switching to the 730 ecm.So I guess it has spare input?
Old Jul 10, 2002 | 02:58 PM
kvu's Avatar
kvu
I know this sounds lazy but what about a patch to add the needed code for an input.It would complete the w/b package.My wb pcb fits inside the 165 case.I could run the wb sensor output to the ecm case.Then read the wb a/f ratio from the aldl.It would be self contained.Would it overheat the pcb?Will it fit in a 730 case?
Old Jul 12, 2002 | 11:30 AM
kvu's Avatar
kvu
I think this post is not wothy of bieng sticky anymore It has gone stale.
Old Jul 27, 2002 | 11:04 PM
86Red4+3's Avatar
I'm liking this thread a lot and plan to hook in the WBO2 when I get it built.
I have a 6E source that assembles to the identical bin (APYP, manual version of ARAP), if anybody's interested. I recently made the code totally relocatable and have put in some time (with a capital T) trying to add commenting. It assembles using AS150 (sorry, don't remember where I got that, maybe somewhere on diy-efi?) The source code is at:
//ftp.diy-efi.org/incoming/APYP7165-relocatable.asm
Feel free to comment out the areas I haven't gotten to yet! I have a burning desire right now to figure out the transmission code/calibration sections.
HTH,
Jim
Old Jan 13, 2003 | 01:06 PM
dgoodhue's Avatar
I know this post pretty much died, but I am interested in attempting to make this work for the $6e ARAP code. My car is off the road till April so I won't be able to test it or finish it for a while, but I will start working on it in my spare time.
Old Feb 4, 2003 | 10:12 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
TPI WB datalogging
Still reviving this from dead..
I finally got around to building a WB kit
of my own to play with, so I went again
and coded up an AFR lookup table for
some TPI bin files..
http://www.eecis.udel.edu/~davis/z28/WB_hacs/
I should have more of the bins tested
in the next few weeks and can post them
alongside the AUJP hac..
mike
Old Feb 6, 2003 | 11:37 PM
Morley's Avatar
I don't suppose this post could be made into its own catagory? Or maybe a Sub-catagory of DIY PROM? That might make it easier to keep track of.
I know nothing about writing code or disassembling code, but it looks like I'm going to give it a whack when I get a WB board built and get it up and running.
Old Feb 7, 2003 | 06:37 AM
85MikeTPI's Avatar
It's probably not wide-spread enough to be
made into it's own catagory.. (Esp now
that the WB sensors are on nationwide
backorder)
But as I say on my web page, I'm willing
to help/share code with anyone interested
in porting this to another ECM...
mike
Old Feb 7, 2003 | 10:18 AM
Morley's Avatar
Thanks for the link and info.
If anyone is looking for the O2 sensor for the DIY-WB and doesn't mind using a used one, you can try here http://uneedapart.com/
Old Feb 7, 2003 | 12:10 PM
dgoodhue's Avatar
backorder)
Thanks Mike
Old Feb 23, 2003 | 04:42 AM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
is there no follow up on this, it seems to me that any aid in finding out what our engines are asking for, would save time and put the stand alone engine managment people in there place,,, i would really adore being able to view the AFR in Craig's software... tuning my 6e with a mod/MAF would be alot easier and allow me to add other options, {namely a ECM controled Electronic Cut out}....
Old Feb 23, 2003 | 08:12 AM
85MikeTPI's Avatar
The '7165 ECM is not as flexible as the
'7730 MAP ECM,and there doesn't seem
to be any available ground referenced
inputs to feed the WB data into.
It may still happen, but it may be alittle more
work than the code-only '7730 hac.
mike
Old Feb 23, 2003 | 09:03 AM
fun Pain's Avatar
Transmission: 4l80e
that will work too, i have a 90 vette/auto, that i could test it out on, so if it works out as a great addition, i will definally switch to SD on the Bird
Old Feb 24, 2003 | 09:07 AM
87400tpi's Avatar
Now I have the 730 .But it would be nice to have a switch in winbin to turn on w/b input.The coding is the part I can't do.But is seems to be a popular idea.So could'nt you programmers out there make it happen?I'm sure there is enough talent on this board to do it,no problem.
Old Feb 24, 2003 | 10:53 AM
85MikeTPI's Avatar
At least with my WB hac, it's not just one
switch/flag, but changing 7 bytes and
adding 100 bytes of code.
A "patch" program would be relatively easy
to do (I know some VB programs already
exist) but would be custom for each BCC.
I just presented the base bin with the hac
applied to it so people that are used to using
editors like Winbin, could just add their
custom data to a base bin already containing
the hac..
mike
Old Feb 24, 2003 | 11:05 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
the hac..
mike
Hi Mike, a patch program already exists. Check the 'patch method demo' sticky.
RBob.
Old Feb 24, 2003 | 01:35 PM
85MikeTPI's Avatar
RBob.
I've read that (At least I thought I did?)
and didn't think that's what it was??
I'll have to go back and read it a little
more carefully and digest it.
If so, I'll add the patch file on the website
along with the bins..
thanks
mike
Old May 13, 2003 | 12:53 AM
OMINOUS_87's Avatar
You guys are incredible!
I have downloaded the modified bins from Mike's site, for both SD and MAF. I have a WB O2 on order and will be building the controller "board-box" this month sometime. My question is the following: Can you run the VOUT from the controller to both the ECM and an LED display or only 1 at a time?
Old May 13, 2003 | 06:08 AM
Car: 87 T/A
I put together a patch that brings the WB voltage in to MAP2 of a 165 under 6E code, and am using a display simultaneously. Seems to work fine. There's a very minor offset (ca. 14.9 vs 14.7 or something like that), but I have no issues.
Old May 13, 2003 | 06:53 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
One at a time, it seems the WB has a floating ground or something. Both my readings were pegged when I tried it.
Old May 13, 2003 | 09:41 AM
OMINOUS_87's Avatar
Craig
Is it an ARAP base with just the code change? Do you have a copy available for DL?
