Good/better/best ignition wires...
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
What's everyones choice? Currently using a random MSD wire set, but one is arching (bandaid fixed) and another boot has somewhat deep nicks. Anyway, i was looking at those Accel ceramic ones, but would like some opinions. As i have limited experience with this area.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Good/better/best ignition wires...
If you have headers , ace or accels are a good choice with the ceramic ends. Not sure if they would work but I have a new set of ace 135 degree ends but you might want 90s.
https://acesefi.com/products/black-j...ark-plug-wires
https://www.facebook.com/share/5LH1KdbrAwh562LH/?mibextid=79PoIi
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Stock with the stock metal heat shields. I bought granatelli coils and wires and they lasted 2k miles before they started to die and cause all kinds of misfires. Went to stock LS3. I was duped by aftermarket ignition parts. Stock GM for the win, especially when it comes to coils.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I have stock manifolds, straight boots. The ace look like accel. Summit sells ceramic wires under their name. They look like accel too. I having second thoughts though after i read the reviews.
Which granatelli wires did you get? I have the DUI "Sultans of Spark line of coils, very reliable. The MSD were fine too till recently.
Car: '90 RS
Engine: 377 LSX
Car: '89 Firebird
Engine: 7.0L
I have MSD wires with Hinson sleeves. I like that the MSD can be bent to any angle you want. Each one is custom bent for my headers.
Car: '90 RS
Engine: 377 LSX
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Cheapest you can get. For me? Those are "The Best", and work as good as high $$$ stuff.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Qwk, which msd set you have? I thought I could angle mine, but they won't bend.
I don't regret selling my stock wires, but I kinda do my stock coils. I've heard good things about them, but those "sultan" series coils are really good. Even msd, accel, petronix have quite a bit of bad reviews.
I'm sorry to hear about your granatelli wires. Their reviews are pretty good, but only on the more expensive set, $250 something. Their cheaper line of wire sets have about amount of so-so reviews as the other brands.
I had the 85KV extreme series coils and their plug wires with the heat shielding. If you take apart the wire assembly it appears that it is just a normal cheap plug wire with a bunch of fancy heatshrink with a fiberglass boot. The coils are what upset me the most. They were extremely expensive and I thought they would be a better upgrade over stock GM and I needed to buy coils anyways.
Car: '90 RS
Engine: 377 LSX
Where do you find those "sultans"? I only see the malevolent series that I had on their website.
EDIT: NM, they are their own brand.
Car: '90 RS
Engine: 377 LSX
Car: 1983 Z28
Engine: 385 Fastburn
Engine: LT1, L400
Yep. Ignition parts area total waste of money, unless you have a situation where some part of it is not working. In addition to no power gains, you get the added benefit with aftermarket parts, of unreliability to boot!
They did something similar to that; they tested a ~630 hp engine with all MSD everything, and then tested again using OEM parts that they pulled from a junk yard motor. Wires, cap/rotor, coil, ICM, everything. The junk yard parts made ~3 more hp.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I noticed a decent improvement in seat of the pants performance. Start and idle quality improved a bit too. Not so much for the msd wires though.
Car: '89 Firebird
Engine: 7.0L
Car: '89 Firebird
Engine: 7.0L
Engine: LT1, L400
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Most of those better coils are OH cam engine type i believe. Funny how the smaller, compact ones did better. Except for that #1 spot. Which kinda looked like an LS style...or was it?
Were they just testing OE coils? Was hoping for aftermarket comparisons too.
Engine: LT1, L400
AFAIK, the coil will put out whatever is required to overcome the resistance to jump the gap, and no more than that. That's what my prof taught us a few decades ago, and you can witness that on a basic scope, hooked up to a running car.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yeah, it was a bit rambling before the guy actually started testing the coils. Most of those names I never heard of.
Higher Compression Ratios are not so much an issue...
However when Cylinder Pressures get high enough from Forced Induction, the Spark Plugs can experience what is referred to as Blow Out.
Really it is the inability to form the Spark in the first place.
Increased Coil Dwell Time/ Spark Energy is needed to remedy the issue.
Capacitive Discharge Ignition Systems can definitely benefit from Low Resistance Ignition Wires and Non-Resistor Spark Plugs...
However most of us need need the Noise Suppression and can Not use Non-Resistor Spark Plugs and Ultra-Low Resistance Ignition Wires.
Inductive Systems do actually perform better with some Secondary Resistance.
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
I'm running D585 coils with the heat sink on them with some eBay plug wires on my turbo car. They work great
12SecondTA
Mar 2, 2006 09:29 AM
Homer
Aftermarket Product Review
Feb 22, 2003 07:07 PM
