tunerpro wrong Parameters
Car: Firebird
Engine: 3.1
Transmission: 700r4 /borg warner t5
i got a problem with tunerpro i downloaded and opened the $88 V6 xdf and ads files but the parameters are all messed up and don't make sense
for example injector flow rate 1.62 ,coolant fan on at -4c ,cylinder 142 , spark advance and everything else
somebody know what cause this?
thanks
thanks
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: tunerpro wrong Parameters
What bcc is being viewed ? Have you tried the newest version of tp ?
http://tunerpro.net/downloadApp.htm
Car: Firebird
Engine: 3.1
Ive got the newest version tp
ive tried it with different bin and definitions but its all the same
Engine: Lb9
Transmission: M20
Cyl should be 192, you can upload your bin to see if the bcc looks right. Maybe you have bad bins.
http://www.gearhead-efi.com/bithoist/query.php
Car: Firebird
Engine: 3.1
i tried v8 bins and definitions but its the same
Engine: Lb9
Transmission: M20
Broadcast code the 3-4 Letter identifier on the proms silver sticker. Offsets right in your read ? Mask show in the hex ?
Car: Firebird
Engine: 3.1
Engine: Lb9
Transmission: M20
ARPL was superseded to BAWX see if this data looks good its a 32k file size
Car: Firebird
Engine: 3.1
thanks a lot now this one works all other don´t
is there a way to eliminate the throttle hang between shifts on the manual transmission cars?
i think its called the throttle follower it is very annoying
Car: Firebird
Engine: 3.1
Engine: Lb9
Transmission: M20
You definitely can play with throttle follower . Iirc it’s for stall control.
Car: Firebird
Engine: 3.1
