Trade 36# injectors for...
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
I'm looking for a set of 30# injectors. I have a set of 36# injectors, white, LS1 style. Too big for my combo.
I could probably even use a set of 26#.. let me know.
Lets trade.
-- Joe
Lets trade.
-- Joe
Re: Trade 36# injectors for...
And all injectors are rated at SAE.
"1996-up 3800 Series II Supercharged (white LS1-style) -- 36 lb/hr"
-- Joe
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
How much HP is your motor making? I'm going to be droping almost the same motor as you this winter - 350, TFS 23, slightly smaller cam, Lt1 intake. I need injectors for it. I bought (6) Grand National injectors with intentions of buying another set since they are in the high 20 range ( 28 or 29 I think) but I finally thought that they would be too small or on the boarder line of being too small. I was thinking that 36 might be right. What problems are you having?
Sometime in the future, I'll be selling the CC306 cam on here.
I know your thinking "Dude, your gonna lose 50hp!" but the bottom end was built to support 800hp+, so I'll take a 50hp N/A loss if I can squirt it with a 250 shot for the track.
-- Joe
ttt
Car: 87 IROC
Engine: 5.3L
you interested in Grand National injectors? I have 6, they aren't worth much but they are in the high 20 lb range. You could probably pic up another 6 for cheap.
Otherwise, interested in selling outright?
Received 1,672 Likes
You say LS1 style... round connector? What injectors are they exactly? Bosch, Siemens, RP, etc.
I have a set of virtually brand-new Frod SVO 30#ers (Bosch 0280-150-945, F1SE-E5A) I would trade, depending on what yours are.
Pic:
Pic:
Last edited by sofakingdom; 08-23-2007 at 08:56 AM. Reason: Automerged Doublepost eliminated my pic!!!
part # when today and report back to you. They use the standard connector
on all the fbody/ybody's, not the newer style connector. I say LS1 style because thats what I was told when I bought them, but I ran the numbers at the time to tripple check they were infact 36# at SAE pressure, not some crazyness.
You and I have, if I recall, conducted a transaction before with pleasurable results.
-- Joe
We have indeed...
Let me know what you find out.
Thanks!!!
Thanks!!!
Here is the # on the side of the injector:
0280155868
picture:
https://www.thirdgen.org/forums/atta...tors-36lbs.jpg
ls1tech:
http://ls1tech.com/forums/archive/in.../t-340042.html
misc:
search for: 0-280-155-868
http://users.erols.com/srweiss/tableifc.htm
Let me know!
-- Joe
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
If you don't have any luck with the others, I have a set of 28# LS6 injectors I'll trade you. I ran them in my 383 for one season, until the 427 was ready to drop in with 36's.
Traded to sofakingdom. Thanks.
-- Joe
-- Joe
