Complete Accel Pro Ram single plane EFI
Car: 79 Monte Carlo
Engine: 406
Transmission: 2004-R
Axle/Gears: Phord 9 inch/3.90
Selling a complete Accel Pro Ram single plane EFI setup.
All sensors included, 36# injectors and 1200cfm TB. Throttle linkages, air cleaner, thermostat housing and distributor hold down not included.
This was a running setup a couple days ago. $600.00.
Would also give a fair trade price for a clean non vortec RPM air gap intake.
TPI79MC@aol.com
TPI79MC@aol.com
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Complete Accel Pro Ram single plane EFI
interested
Can't find any online info as to gasket/ port size ?
Also ; when you say no Throttle linkages,
are you talking about the linkage between the 2 TB shafts?
Car: 79 Monte Carlo
Engine: 406
Sorry, I should have been more clear on that. The TB is complete, you just need your own throttle bracketry for the throttle cable.
This intake casting was much nicer than any RPM air gap I've had. It was 1205, but I gasket matched it closer to a 1206 as thats what my heads are.
Car: 1991 RS
I have the same pro ram manifold. Never removed from box. I also have injectors and the 1550 throttle body. Same physical size as the one pictured but more flow. Is there still interest?
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
How much are you asking?I would be interested
Car: 1991 RS
Yeah. That's the one. Imagine cutting the circles out into one big square. The primary blade opens about thirty degrees, then the secondary starts to open, and they reach WOT simultaneously.
Want pics?
Want pics?
Car: 1991 RS
The manifold is $500 new. The throttle body is $450 new. Neither have been installed, ported, or modified.
What say $750 shipped?
Terrell351
06-13-2021 01:13 PM
